Suspension - Mustang Evolution
Old 01-09-2012, 10:52 AM   #1
NeedSomeMods's Avatar
Suspension
Okay, really wanting to upgrade my front suspension soon.
My front tires are wearing really bad, unevenly, and ride quality is not so great. I want to upgrade the suspension and have it all aligned before I put a brand new set of tires on.
I'm looking for Bang-for-Buck type stuff, but willing to spend a little if needed.
So far I'm thinking:
BBK Specific Rate Mustang Lowering Springs (79-04 V8) 2501 - Free Shipping!
Tokico HP Series Strut (94-04 Mustang) HB3140 - Free Shipping!
and new isolators, bushings, etc.
I'm just not sure about all of the bumpsteer issues, and what exactly bumpsteer is.
Are the Steeda X2 balljoints, and bumpsteer kits worth it?
I'm really open to ideas on this and would really appreciate the feedback.
Keep in mind, I can't drop/slam the car as it is my DD and drive on some pretty rough roads. I don't think I'll need C/C plates.
---------- Post added at 11:52 AM ---------- Previous post was at 11:41 AM ----------
What is the difference between specific/progressive rate springs?
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 01-09-2012, 11:05 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Suspension
IF u drop less than 1.5-1.7 you prolly shouldnt need the "bump steer kit/x2 ball joints", and if your alignment guy is worth a crap u shouldnt need cc plates either (if staying under 1.7). i have 2.0 drop on my sn95 with no cc plates. my car is set-up close layla/amies' s set-up and im pretty happy.
however, if your concerned bout ride quality and dealing with rough roads.... u may wanna reconsider goin with "specific rate" springs. and instead go with "progressive rate" springs. if you like having that road racing (stiff all the time) race car feel all the time then go with specific rate springs... not to mention you will need to adjust the way drive a bit in wet weather with specific rate. i prefer specific rate personaly, but for dd most ppl go with progressive.
hope this info helps.....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-09-2012, 11:51 AM   #3
Re: Suspension
That helps a lot! Thanks.
I think I'm leaning more towards the
Eibach Sportline Spring Kit (79-04 V8 Coupe; 99-04 V6 Convertible; Excludes 99-04 Cobra) 4.1035 - Free Shipping!
Progressive Rate, 1.7" drop in front, 1.5" rear.
So I shouldn't need the extra stuff with this set-up.
Is there a particular brand/type of strut I should be looking at?
I don't think I need the adjustable kind as I don't plan on racing.
2000 V6 - RIP
The '94 -
Old 01-09-2012, 12:29 PM   #4
Titus Wadicus
svtlx's Avatar
Re: Suspension
I just got the (almost)top of the line autozone struts (typicaly wutever they list as "heavy duty" or "special service" is what i get cause they stay stiffer longer than the other brands)... just dont get the cheap ones. you should b pretty happy.
anything past 1.5 your alignment guy will need to drill the rivets outa the stock cc plates so he can correct the camber to spec. you shouldnt need anything else.
Old 01-09-2012, 01:08 PM   #5
Re: Suspension
I'm going to order all of the parts from AM.
What do you think about these?
KYB GR-2/Excel-G Front Strut (94-04 All) 235060 - Free Shipping!
Cost >$60 ea, and claim to be Better than OEM. All reviews are positive and rated 4.6/5
2000 V6 - RIP
The '94 -
Old 01-09-2012, 01:14 PM   #6
Titus Wadicus
svtlx's Avatar
Re: Suspension
kyb is a popular choice for street and mild track suspensions. go for it.
Old 01-09-2012, 01:54 PM   #7
I have those on my car with no complaints.better than stock.
Old 01-09-2012, 01:58 PM   #8
My preference: http://www.maximummotorsports.com/store/
Kjohnson1 is offline   Reply With Quote
Old 01-09-2012, 02:22 PM   #9
Re: Suspension
Maximum motorsports would be my preference if I could in fact afford it.
What I can get for $500 through deal shopping would be about $1500 for MM stuff.
Thanks dreamstang.
If I can get a good used set of C/C plates, would that be better to use than having rivets drilled out?
2000 V6 - RIP
The '94 -
Old 01-09-2012, 02:33 PM   #10
Titus Wadicus
svtlx's Avatar
Re: Suspension
Thanks dreamstang.
lol...no. cause they would have to drill them out to install the new cc plates anyway. if u want cc plates then by all means get them. i was just tryn to save u a couple bucks. they wont hurt if u get them, but u most likely wont notice any difference in steering input or excessive tire wear without them. and i seriously dought your alignment can can invent xtra adjustment unless he notches the towers (i did). you will gain sum caster adjustment, but itsa a street car, not a nascar or scca car.
like i said, anything 1.5 or lesser drop cc plates are a waste of your money. even at 1.7 you wil be super close to spec.
Old 01-09-2012, 02:59 PM   #11
Thanks dreamstang.
Scope the 'sale' section at maximum motorsports
Old 01-09-2012, 03:11 PM   #12
Re: Suspension
Alright. Just trying to make sure.
I've never even seen a sale section at MM.
Thanks for all the help guys. I'll let you know what I decide.
2000 V6 - RIP
The '94 -
suspension?? thomas91gt 1979-1995 Mustang GT 1 12-29-2011 11:50 PM
Suspension work-arounds? ColeJohnson 1996-2004 Mustang GT 3 12-13-2011 08:55 AM
66 suspension gc19662007 Classic Mustangs 5 11-26-2011 08:38 AM
Coupon Code for Stallion Suspension WaldoGT07 2005-2010 Mustang GT 0 10-16-2011 09:06 PM
Suspension TommyTsunami88 General Mustang Discussion 5 08-29-2011 01:25 PM
05:41 PM
