Unexplained coolant loss - Mustang Evolution
Old 01-09-2012, 11:56 AM   #1
I've got an 89 GT and I'm experiencing an odd loss of coolant. After a few days the radiator will be half empty (half full for you optimists) but I can't seem to locate where it's going. The engine is running good. There is nothing leaking on the engine that I can see and I'm not leaving any puddles on the ground.
There is no water in the oil either.
I'd appreciate any advice on where it might possibly be going or what to look for. Thanks in advance for any help.
Dan...
dvtusn is offline   Reply With Quote
Old 01-09-2012, 12:05 PM   #2
86TBarHatch's Avatar
Region: New Hampshire
Any puddles or dampness on the passenger floor? Any white smoke when the engine is running or under acceleration?
86TBarHatch is offline   Reply With Quote
Old 01-09-2012, 12:11 PM   #3
Titus Wadicus
svtlx's Avatar
Re: Unexplained coolant loss
have u checked the plugs? i bet you got a pinhole leak near an exhaust valve on one of your head gaskets
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-09-2012, 02:35 PM   #4
Fredfifty's Avatar
Ive heard of it misting out of the exhaust...not sure if thats your issue.
Rest in Peace Edson Veloro
89 LX Coupe 5.0 - SOLD
91 GT Vert 5.0 -CURRENT
07 TBSS - CURRENT
Fredfifty is offline   Reply With Quote
Old 01-09-2012, 04:20 PM   #5
Agreed.
If it is not showing up anywhere then it is likely that you are burning it.
Old 01-09-2012, 08:07 PM   #6
look at the condition of the block plugs to make sure they are not rusted through. Also make sure your oil looks normal and not like chocolate milk.
Kjohnson1 is offline   Reply With Quote
Old 01-09-2012, 10:52 PM   #7
Well, I already checked the floor to make sure it wasn't the heater core. I just replaced it 2 years ago so it should be good.
Oil is perfectly clean and I don't see any white smoke from the tailpipes. I'll definitely check the plugs though and see how they look.
Old 01-10-2012, 05:19 AM   #8
bryanbrock's Avatar
might be intake manifold failing.
bryanbrock is offline   Reply With Quote
Old 01-10-2012, 05:54 AM   #9
Make sure it ain't building up to much pressure while your driving it and pushing it out of the vent hole in your overflow tank if u have one. I've seen them do that before
Robbie94gt is offline   Reply With Quote
Coolant light problem Albo22 1996-2004 Mustang GT 2 01-09-2012 02:04 PM
Cracked muffler/ pressure loss? Kgstang 2.3 Mustang 4 01-04-2012 11:58 PM
Sudden loss of HP? jjsg09 1996-2004 Mustang GT 2 10-03-2011 02:59 PM
Coolant Type crkmonzo 1979-1995 Mustang GT 3 09-11-2011 01:18 PM
horrible coolant leak...ideas? shustwit Pre-2005 V6 Mustang 3 06-30-2011 01:48 PM
08:25 PM
