heads - Mustang Evolution
Old 01-09-2012, 05:48 PM   #1
heads
hey their is a video of a 302 sn95 with 351 heads can you really do that and is it a good hp torque advantge
kid_kash_00 is offline   Reply With Quote
Old 01-09-2012, 05:54 PM   #2
There is no big or any gain using 351 heads.
Old 01-09-2012, 05:59 PM   #3
From 77 or so the 302 and 351w heads were the same aside from the 1/2 inch head bolts. The first years of 351w heads were bigger valves and better flow.
Dexter is offline   Reply With Quote
Old 01-09-2012, 06:03 PM   #4
Re: heads
351W or 351C heads?
Old 01-09-2012, 06:14 PM   #5
Re: heads
dunno he just said 351 heads on a turb 302 it was pretty fast he swaped 351 for turbo 302 and swaped heads i wann turbo min but dont if i even need heads im looking at either new stang or turbo or supercharging min i want a low 13 high 12 stang
Old 01-09-2012, 06:16 PM   #6
Titus Wadicus
svtlx's Avatar
Re: heads
nope, no advantage. i think that works in chevy world though lol.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-09-2012, 07:53 PM   #7
Re: heads
Well, if he used 351C heads, then you would likely see some improvement.
Otherwise like everyone else said no appreciable gains would be noticed.
Putting 351C 4V heads on a 302, basically makes it into a version of the old style Boss 302, which they call the "Clevor".
See this article for more information - Clevor Engine
A TC would be your best option to meet your goals.
Old 01-10-2012, 07:40 AM   #8
Re: heads
Thank guys
Good Information Thread. ESG642T Pre-2005 V6 Mustang 10 01-13-2012 08:00 AM
New to this...gt40p heads vs 351 Windsor.. Ponyboy66 1979-1995 Mustang GT 8 12-30-2011 10:24 PM
Dart Iron Eagle heads deadsp0t 1979-1995 Mustang GT 19 12-23-2011 04:59 AM
E7 heads or Gt40 heads? Qwik Four Six 1979-1995 Mustang GT 18 10-29-2011 09:59 PM
Cumbustion chamber size Mustang1968kr 1979-1995 Mustang GT 2 08-23-2011 11:51 AM
04:56 AM
