Shifter does not move linkage on my trans? - Mustang Evolution
Old 01-10-2012, 01:42 PM   #1
Mustang5's Avatar
Region: Rhode Island
Ones anyone know why my shifter doesn't move my linkege on my tranny?
Mustang5 is offline   Reply With Quote
Old 01-10-2012, 01:59 PM   #2
What do u mean? The shifter is stuck? Or it just doesn't change gears?
Old 01-10-2012, 02:42 PM   #3
Mustang5's Avatar
My shifter won't move my linkage on the tranny but if I go under the car and and move it it works
Old 01-10-2012, 03:13 PM   #4
It's not me, it's you.
primer2tone's Avatar
It might have too much play in the linkage. Or it may be broken somewhere along the line. Have you had someone try to move the shifter while you watch the linkage from underneath?
Old 01-10-2012, 03:55 PM   #5
Mustang5's Avatar
I just got the tranny rebuilt
Old 01-10-2012, 06:41 PM   #6
Re: Shifter does not move linkage on my trans?
Automatic?
If so then your cable is not fastened down properly at the transmission and instead of the inner cable moving the linkage the whole cable is moving instead.
Old 01-10-2012, 06:41 PM   #7
Did the rebuilders install the transmission? If they did or who ever did, might have over looked something. It might be loose or not connected at all.
Old 01-11-2012, 05:20 AM   #8
Mustang5's Avatar
They rebuilt it then I put It back in
Old 01-11-2012, 11:15 AM   #9
I would tell them the problem you are having with it. It sounds like the linkage may have not been tightened up and has too much play in it. If you can't take it apart and see what's wrong I'd say take it back and they should fix it.
66 engine and trans rebuild Sullivanmedia Classic Mustangs 1 01-08-2012 02:35 AM
auto shifter cable to steering wheel. Black_Sunshine Pre-2005 V6 Mustang 4 10-02-2011 06:54 AM
Steeda Tri ax short shifter install..... rinfield2004 SVT Mustang 10 09-02-2011 12:40 AM
Short Throw Shifter bmabbott Pre-2005 V6 Mustang 11 08-17-2011 03:03 PM
Trans Downshift Jolt crkmonzo 1979-1995 Mustang GT 3 08-16-2011 08:35 PM
12:38 AM
