Throttle body - Mustang Evolution
Old 01-10-2012, 06:47 PM   #1
jwhayne0001's Avatar
Throttle body
I've been peaking at AM's bbk 70mm throttle body paired up with a CNL cold air, do I need to do anything to my cobra intake? And would a tune be required?
jwhayne0001 is offline   Reply With Quote
Old 01-10-2012, 06:55 PM   #2
WhiteCobra94's Avatar
As long your cobra intake has a 70mm inlet you will be fine, when it comes to retuning I don't think so but you will get more performance out of your mods if you did!
Old 01-10-2012, 06:57 PM   #3
Anyone know what a 95 cobras stock intake inlet is?
Old 01-10-2012, 07:00 PM   #4
I believe it's 70mm I'll double check my intake when I get home it's in the garage!
Old 01-10-2012, 07:02 PM   #5
Re: Throttle body
I believe they are listed at 70MM, however you may need to clean it up a bit depending upon casting flaws.
Old 01-10-2012, 07:13 PM   #6
Hopefully it already is 70, and im hoping for no flaws but I'm sure I'm not so lucky
Old 01-10-2012, 07:24 PM   #7
89white GT's Avatar
Region: Iowa
Just call American muscle and ask them. Thats what I did with my rims. They were very knowledgeable and made me feel alot more confident about my purchase
89white GT is offline   Reply With Quote
Old 01-10-2012, 07:39 PM   #8
Re: Throttle body
It's no big deal to clean it up or to open it up if it is needed.
A dremel tool will work, a regular die grinder will work even better and in a pinch you could even use a die grinder aluminum cutting bit in a drill if you have to. Follow that up with a bit of sanding roll smoothing and you're good to go.
Just stuff some rags into the opening (make sure you get them all back out) to keep out metal particles and cut a hole in an old blanket, tarp, sheet of plastic, etc. and put it around the intake to keep the particles out of the engine bay. Cut and polish the opening to the size you need (mark a line by using the gasket) then vacuum up the metal shavings, remove the cover and rags, double check for any stray particles, install the new TB and you're good to go.
Old 01-10-2012, 08:43 PM   #9
Is the upper easy to remove? Just TB and bolts right? I'd rather remove to be safe
Old 01-10-2012, 08:47 PM   #10
Re: Throttle body
Yes, just be careful and follow the torque sequence and specs when re-installing.
Old 01-10-2012, 08:53 PM   #11
Ok, I have access to workshop manuals at my work I just would feel ALOT safer removing it from the car with metal shavings, an ounce of prevention is worth a pound of cure!
Old 01-11-2012, 05:32 AM   #12
Re: Throttle body
Agreed!
Aluminum doesn't bother me as much as steel would, but it could cause some problems for sure if it got into the wrong place.
Old 01-11-2012, 09:42 AM   #13
Mdavis1024's Avatar
I put a 70mm BBK on my 91GT. I think taking off the upper intake is more headache than is needed. Just giving the other side of the coin. There is a greater chance of something getting between the upper and lower intake. There are also gasket issues to contend with, torquing and re-torquing the bolts. As long as you keep your work area clean there would be no problem. I like painters tape on metal because it comes off really easy. I love my TB. You only really have to get a good tune in there if you couple the TB a new MAF which you need if you up your fuel injectors. Just adding more air intake with the TB will increase HP. If you want to get down to the brass tacks then a smooth mating of the TB to the upper intake will reduce intake turbulence. Plus, an air compressor will save a lot of heartache because you're able to blow clean any loose material.
Mdavis1024 is offline   Reply With Quote
Throttle body and short throw shifter Mayhem48 General Mustang Discussion 14 01-28-2014 09:22 AM
Throttle Body? 2011CS 2011-2014 Mustang GT 2 11-14-2011 06:28 AM
Throttle Body Whistles GTtopgear General Mustang Discussion 8 08-13-2011 09:24 AM
Throttle Body Spacers jbanks 1996-2004 Mustang GT 5 07-11-2011 08:43 PM
Throttle body cleaning Mustanglife Pre-2005 V6 Mustang 10 07-04-2011 01:32 PM
07:38 PM
