Turn signals 87 5.0 mustang - Mustang Evolution
Old 01-11-2012, 06:10 AM   #1
Ok so I have seen that this is an ongoing problem in these models, so let me explain.
I just got an 87 5.0 and have been fixing a number of things the previous owner screwed up. There were lots if connections that were unhooked to everything that I have been putting back together. However after all this my front blinkers will not come on. If I turn the headlights on they come on. Don't flash just light up. My hazards flash in dash and in rear. When I put turn signal on the backs come on but no flash. Any suggestions? I did notice the fronts are a double filament but inly have two wires run in to the fitting.
Giles85 is offline   Reply With Quote
Old 01-11-2012, 07:54 AM   #2
Re: Turn signals 87 5.0 mustang
Probably your turn signal flasher or the turn signal switch.
If you don't have one pick up a Chilton's or Haynes manual that has the wiring diagrams.
That will help you trace out wiring problems and failures.
Old 01-11-2012, 08:16 AM   #3
Well got both new flashers. And would my lights on dash come on if the switch was bad. Also about the front lights being double filament, should it only have two wires going in?
The front has new fixtures and some new wiring
Old 01-11-2012, 08:33 AM   #4
Would the dash lights turn on if the switch was bad?
Yes, no, maybe. It's hard to tell what someone else may have done to the wiring.
You're going to have to trace the wiring and see if it is still wired correctly or if it has been hacked up.
Get the correct bulbs for the front lights and yes, two wires is what it should have.
If it has the wrong bulbs it may not be making the proper connection and could be interfering with the circuit power flow.
Old 01-11-2012, 09:08 AM   #5
Mdavis1024's Avatar
Try the relay behind the glove compartment. There should be a round cylinder-type fuse under there. You should be able to test the continuity to make sure it is good. I had the same problem in my 91 GT. If that isn't the problem the. You will have to get a wiring diagram and use a whole lotta multimeter skillzzzzz.... I can post a picture of a diagram when I get home I you need one.
Mdavis1024 is offline   Reply With Quote
Old 01-11-2012, 10:09 AM   #6
Yea cause I replaced both relays. Post that diagram if u could. Also I have a bad idle surges, is it iac,egr, or pcv? And do u know the exact purpose of the egr delete. Cause what I have read gives no pros to doing this
Old 01-11-2012, 10:42 AM   #7
Mdavis1024's Avatar
Surges can be any number of reasons. Make sure you adjusted the TPS with the new TB. That might solve the problem.
I have bypassed my EGR. I didn't take it off because then I would have to plug the hole left behind which would cost me the price of a fitted delete kit. If you bypass it then you will have to plug all the vacuum lines running to it. There could be surges if not all the vacuum lines are used or capped off.
Old 01-12-2012, 07:44 AM   #8
Mdavis1024's Avatar
The manual I have doesn't cover below 1989. I posted the picture that I have. If it is too hard to read you can try a web search. I forget the name of the site that I used before but they are out there. I hope it helps.
Old 01-14-2012, 06:44 PM   #9
Which light is the blinker. Is it the outside or the inner light. If its inner I have found the problem.
Old 01-14-2012, 06:58 PM   #10
93slowstang's Avatar
Outside lights on my 93. Don't figure the 87 is different.
Old 01-14-2012, 07:32 PM   #11
Thats so strange. The way the new lights are set up it makes it to where the inside ought to be. Let me ask this do u think it would be illegal if I put them on the inside? The way the plug goes into the fixture would put them on inside.
Old 01-14-2012, 07:35 PM   #12
Shouldn't be illegal.
Old 01-14-2012, 07:55 PM   #13
351mustanggt's Avatar
mine are actually on the inner part and thats how i bought it and got it inspected
351mustanggt is offline   Reply With Quote
Old 01-14-2012, 08:34 PM   #14
What year u got? Mines 87
Old 01-14-2012, 08:41 PM   #15
mines 88 gt
Old 01-14-2012, 09:37 PM   #16
Ok well mines going on inside too then. Easier anyhow. Thanks for ur help everyone
Old 01-14-2012, 09:37 PM   #17
Cobrarunnin9s's Avatar
The inside is the turn signal the outside is the marker light
Cobrarunnin9s is offline   Reply With Quote
Old 01-14-2012, 10:53 PM   #18
Yea that's how mine is then. It seemed like a dumb question but obviously not cause its different on different models. And yeah that's how mine is. I was told by so many that it was the outside that was the blinker so I couldn't figure it out. The idiot who had it before me done everything wrong so it coulda been anything. Thanks for the help though. That makes things way easier for me.
Old 01-15-2012, 09:00 AM   #19
Mdavis1024's Avatar
There are no dumb questions. "Measure twice; cut once." Better to confirm and be sure then try to fix something, get it wrong, then have to redo it. Or worse, pay someone to fix the fix. (EM)barrassing.
Old 01-15-2012, 10:04 AM   #20
Kinda making me worry about mine being the outside lights on mine.
Old 01-15-2012, 11:45 AM   #21
Mdavis1024's Avatar
If it ain't broke...
Old 01-15-2012, 12:26 PM   #22
The turn signal lights should be on the outside corners so they are more visible to other drivers beside you or even slightly behind the front of your car in signaling your intentions to turn.
If they were mounted to the inside of the headlights, those drivers would not be able to see that you were signaling to turn, which could cause an accident in which you would be at fault.
Both my 86 & 89 Mustangs are this way from the factory.
Most of what I see in a Google search shows the turn signal lights on the outside of the headlights and the running lights on the inside of the headlights.
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
05:14 PM
