95 Headlight Swutch - Mustang Evolution
Old 01-11-2012, 05:05 PM   #1
deadsp0t's Avatar
95 Headlight Swutch
K when I bought my car the headlight switch was bad, no running lights or dash lights. Replaced and it's been fine for four months. It just popped again! Any ideas why this keeps happening?
That's unimpressive
Old 01-11-2012, 05:14 PM   #2
It's not me, it's you.
primer2tone's Avatar
Might be the Headlight switch Gnomes! Not to be confused with the Underpants Gnomes. These little bastards go out and soil electronics causing them to short out. When you noticed your switch was out, was the lever sticky? Did it smell like maple syrup?
Lol, jk I've got no clue man. But when you replace this one, take your old one apart. Look for corrosion or indication that the internals may have gotten hot.
Old 01-11-2012, 05:31 PM   #3
Re: 95 Headlight Swutch
Have you changed headlight bulbs to higher powered (more current/amp draw) ones?
Are your fog lights powered through the headlight switch?
Sounds like the switch is being damaged and consequently burned up by too much current/amp draw.
That or check your light's grounds and make sure they are grounded good.
If they are not the power could be back feeding through and destroying the switches.
Old 01-11-2012, 05:37 PM   #4
That sounds logical... But I'll bet it Gnomes.
Old 01-11-2012, 06:42 PM   #5
deadsp0t's Avatar
One fog light is burned out and the other is missing. It wasn't in the carfax but I know it's been hit up front. It is raining but not pouring. It messed up when I pulled the lights on. The fogs are on the center console switch. Weird it's been fine for four months.. I think it's under warranty at auto zone so probably won't get to dissect it.
That's unimpressive
Old 01-11-2012, 07:34 PM   #6
If it has been hit in the front it may have a pinched wire that is shorting out intermittently when the lights are on causing the switch to overheat because of the excessive current/amp draw.
After numerous cycles of this the switch finally fails because it is weakened each time it heats up.
Old 01-12-2012, 01:44 AM   #7
deadsp0t's Avatar
Weird, after work it started working intermittently but I got it to stay on working it around a little. When I got home I decided to mess with it a little and I couldn't get it to not work.. Just strange..
Not complaining that it's working, I'm just saying.. Weird.
That's unimpressive
Old 01-12-2012, 01:54 PM   #8
deadsp0t's Avatar
And it's working just fine today..
That's unimpressive
Old 01-12-2012, 02:18 PM   #9
Electrical stuff.
Old 01-12-2012, 02:23 PM   #10
deadsp0t's Avatar
I'm glad its working, but its confusing and frustrating
That's unimpressive
Old 02-21-2012, 11:50 PM   #11
deadsp0t's Avatar
Had this same issue again tonight. Will be getting off work soon, sure would be nice if it starts working again as I'll hate riding home(45 miles) with the hazards on..… boooooooo
That's unimpressive
Old 02-22-2012, 12:42 PM   #12
mystang50's Avatar
I saw on American muscle. They have a headlights switch repair plug or something...mine does it to but only if plug gets hot. So with out the heater on I can go for a hour straight before it starts dancing and then I have to hold brights on...I might be buying the repair plug or what ever it is...I've gone threw 3 switches
Old 02-22-2012, 01:34 PM   #13
deadsp0t's Avatar
I will have to look into that for sure. I actually got it working last night.
That's unimpressive
Old 02-22-2012, 01:55 PM   #14
mystang50's Avatar
Good luck!! If u get it and it works tell me
Old 02-25-2012, 08:33 PM   #15
deadsp0t's Avatar
I took it apart to return/exchange and found several of the connector pins were a little loose and or corroded. After messing with the pins(pushing them in, securing them) I now have it working. My plastic plug is disfigured in places, so I want to go to LKQ(a you pull it junk yard) and try to locate a new plug and as much harness as I can.
Is your plug melted or disfigured? Any exposed wiring with corrosion? Might be a good idea to use a tiny screw driver to push the pins down in the plug if you haven't done that.
That's unimpressive
Old 02-25-2012, 09:34 PM   #16
mystang50's Avatar
My plug is black In some connection ports from it getting hot
Need Advice. Mustang Headlight Fogged Up. AllanBane 1996-2004 Mustang GT 3 10-17-2011 07:37 PM
headlight restoration best product? dbroncolish 1996-2004 Mustang GT 8 09-19-2011 05:09 PM
Left low beam headlight wont work but i will when i turn on high beams p1blake04 1996-2004 Mustang GT 4 09-05-2011 11:30 PM
Mothers all in one headlight restoring kit znpzmustang Mustang Paint, Appearance & Detailing 9 08-09-2011 07:11 PM
Headlight Aaron vassallo 1996-2004 Mustang GT 2 07-01-2011 08:10 AM
12:06 PM
