testing ignition coil - Mustang Evolution
Old 01-12-2012, 07:03 AM   #1
Does anybody the proper way to check the coil with a voltage meter to c if it is a weak coil?
Robbie94gt is offline   Reply With Quote
Old 01-12-2012, 09:53 AM   #2
98prosnake5.4's Avatar
Take the coil to autozone they test them free. I can't explain how in a text if you cross it up you will burn it up and sometimes it will blow up play it safe
98prosnake5.4 is offline   Reply With Quote
Old 01-12-2012, 11:12 AM   #3
Re: testing ignition coil
Good advice.
You cannot really test the output side with any easily available or inexpensive testers.
If you know what the resistance should be for the coil you can test it across one that has been disconnected from any power source at the two side terminals with an ohmmeter.
02 Mustang V6 coil question? powellst Pre-2005 V6 Mustang 7 01-10-2012 12:46 PM
coil pack Supersnake4.6 1996-2004 Mustang GT 1 08-30-2011 07:02 PM
Spark plug and coil pack sudgestions? p1blake04 1996-2004 Mustang GT 11 08-30-2011 05:18 PM
Coil overs silver98mustang 1996-2004 Mustang GT 12 07-26-2011 09:26 AM
Changing an ignition 1995 Nate98stang 1979-1995 Mustang GT 23 06-26-2011 10:21 PM
04:43 PM
