Stiff Clutch - Mustang Evolution
Old 01-12-2012, 07:48 PM   #1
89white GT's Avatar
Region: Iowa
Stiff Clutch
My 89 is a 5 speed. It has a world class rebuilt T5 and a stage 2 clutch. For some reason the clutch is really hard to push down. My butt comes off the seat each time I push the clutch down. Is there any way to adjust this??
89white GT is offline   Reply With Quote
Old 01-12-2012, 08:38 PM   #2
Re: Stiff Clutch
Grow a bigger butt?
When this occurs the cause can be a worn, frayed clutch cable or you could have issues with your quadrant or pedal bushing.
With some clutches it is just the HD pressure plate springs.
There is no way to adjust out of this, you will have to locate the problem and repair or replace the parts causing it.
Old 01-12-2012, 09:00 PM   #3
89white GT's Avatar
Region: Iowa
Are any of these parts very expensive?
Old 01-13-2012, 05:50 AM   #4
04machazblue's Avatar
Would say a clutch cable I had that problem and Iam no little guy I didn't notice it till it got really bad and a friend asked why it was so hard to push my clutch, but a clutch cable is 60 bucks for the steeds and maximum motorsports Is 89$
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 01-13-2012, 06:15 AM   #5
It's not me, it's you.
primer2tone's Avatar
Dooode! I had the same problem! Turned out someone dropped a couple of Viagra tablets into the clutch master cylinder! Lmao! No worries, it went away after 4 hours!!! Lol jk
Old 01-13-2012, 06:34 AM   #6
Re: Stiff Clutch
Not real expensive. Check with American Muscle and LRS our site sponsors.
Look on their ME forum pages for site member discount instructions.
For the cable I would go with the Maximum Motorsports "factory" replacement cable.
It is manufactured to original specifications and is much stronger and better built than most aftermarket cables.
Old 01-13-2012, 01:39 PM   #7
89white GT's Avatar
Region: Iowa
That's the one that requires a aftermarket quadrant and firewall adjuster right?
Old 01-13-2012, 02:00 PM   #8
Re: Stiff Clutch
It requires the firewall adjuster, but you should go ahead and replace the quadrant too if it is an original plastic model.
Here is the Maximum Motorsports Clutch Cable Page
Information and comparisons are on the page.
Click the Tech Info button at the bottom to see the quadrant advantages.
Old 01-15-2012, 07:55 PM   #9
89white GT's Avatar
Region: Iowa
Well I just got under there today and checked and it actually has an after market cable, quadrant, and firewall
Adjuster.
Old 01-17-2012, 10:18 AM   #10
skystang93's Avatar
+1
skystang93 is offline   Reply With Quote
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
New guy with a clutch question Cajunick 1996-2004 Mustang GT 7 11-15-2011 11:32 AM
Clutch just went 04machazblue 1996-2004 Mustang GT 9 08-24-2011 05:41 AM
Spec or ram clutch 04machazblue 1996-2004 Mustang GT 3 08-23-2011 04:36 PM
stiff clutch vinnygt 1996-2004 Mustang GT 6 07-12-2011 09:41 PM
09:11 AM
