Track time!! - Mustang Evolution
Old 01-13-2012, 03:04 PM   #1
89 Foxloco's Avatar
Track time!!
So last night I took my foxy for her last run..at the 1/8 it did 10.1 the fastest..I had my tires at 13psi ..I went down to 10 psi and I got 10.3.. For it to be stock with lil things done to it what do you guys think..thanks..
89 Foxloco is offline   Reply With Quote
Old 01-13-2012, 06:00 PM   #2
wc3john's Avatar
Re: Track time!!
is it a 5 speed? a mostly stock 5.0 should run 9.0's with a t5 and slipping the clutch on street tires.
i.e.
before camming mine
Full exhaust with no cats
CAI, 70 mm tb, stock intake and Maf
stock heads and stock gears at 3.08
9.0 @ 76 mph 1/8 with a 2.1 60 ft
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 01-13-2012, 06:07 PM   #3
Region: Iowa
Re: Track time!!
I haven't run mine at the track YET but that seems a little higher then what i was expecting, What kind of sixty foot times did you get?
Bensfoxbody is offline   Reply With Quote
Old 01-13-2012, 06:17 PM   #4
Mostly stock u can probably run higher tire pressure.try 17-20
Old 01-13-2012, 06:18 PM   #5
Re: Track time!!
A 10.00 1/8 mile time equates out to between a 15.83 - 16.00 1/4 mile time.
Most places use the 1/8 mile time multiplied by 1.5832, but the NHRA uses 1.6.
Old 01-13-2012, 10:11 PM   #6
89 Foxloco's Avatar
Yes it is a stock t 5..everything is stock..tire pressure I got better grip at 13 psi than 20..
Old 01-14-2012, 03:35 AM   #7
Re: Track time!!
Running tire pressures that low on street tires can cause you some grief.
If the tire sticks, there is likely not enough pressure to keep the rim from spinning inside the tire bead. I would not go under 20 psi on a street tire.
Be careful.
Old 01-14-2012, 04:57 AM   #8
Eturner's Avatar
Be careful.
+1
Old 01-14-2012, 12:50 PM   #9
89 Foxloco's Avatar
Be careful.
oh ok..thanks for the heads up..
Old 01-14-2012, 09:39 PM   #10
mystang50's Avatar
My 95 full bolt on, shorty, x, 373, auto AODE. ran a 9.6 in 1/8 on 17 by 9 street tires last year
Old 01-15-2012, 09:52 AM   #11
deadsp0t's Avatar
IMO you'd be 8.70's - 9.0 with a 5spd and Drag Radials.. My old 95 was 8.80-9.0 with similar mods 5spd and 2.73's
That's unimpressive
Old 01-15-2012, 10:39 AM   #12
OG86GT's Avatar
I was at about 8.90s @ 77 mph with a 1.85 60 ft
OG86GT is offline   Reply With Quote
Old 01-15-2012, 10:44 AM   #13
deadsp0t's Avatar
Pretty quick for a DD IMO. Wish I had my old slips, thinking my 60ft was 1.6's or 1.7's on my best passes and 2.0's in a regular basis. Can't say for certain though.
That's unimpressive
Old 01-15-2012, 10:51 AM   #14
OG86GT's Avatar
Yeah. I was on 215/65 street tires which I could leave at 3,000 rpm's and dump the clutch
Old 01-15-2012, 10:53 AM   #15
deadsp0t's Avatar
2k was my average launch, any harder it would break out
That's unimpressive
Old 01-15-2012, 10:55 AM   #16
OG86GT's Avatar
I would run around 24 psi in the tires
Old 01-15-2012, 11:02 AM   #17
deadsp0t's Avatar
After I dumped the mufflers right out of the muffler(no tail pipes) I was able to move up to 2,400-2,500. Psi was in the 20's but not for sure exactly it been 8+ years ago lol
That's unimpressive
Old 01-15-2012, 11:03 AM   #18
OG86GT's Avatar
I also have no tail pipes. Stops after muffler
Old 01-15-2012, 01:27 PM   #19
mystang50's Avatar
Yeah I want some drs but they are expensive...but mines auto...and it was my first time ever at a track launching from idle
Old 01-15-2012, 01:30 PM   #20
deadsp0t's Avatar
Not bad for your first go at it. Takes practice to get good at drag racing, no two ways about it.
That's unimpressive
Old 01-15-2012, 01:49 PM   #21
mystang50's Avatar
Yuuup
Old 01-15-2012, 09:42 PM   #22
Region: Iowa
You guys are making me wanna race BAD
Old 01-15-2012, 11:00 PM   #23
mystang50's Avatar
Ik makes me wanna go buy some dr's
Old 01-16-2012, 12:10 PM   #24
OG86GT's Avatar
I have some 275/50 mickey thompsons on right now that barely fit due to my car still having the quadshocks still on
Old 01-16-2012, 12:30 PM   #25
Re: Track time!!
Install some aftermarket LCAs and get rid of those quad shocks.
Old 01-16-2012, 01:40 PM   #26
OG86GT's Avatar
Oh of course I will when I get some more money flat broke right noe but quadshocks are coming off
Old 01-16-2012, 02:15 PM   #27
Re: Track time!!
Been there, unfortunately still there and I can understand that all to well.
I have the old Southside Lift Bars on my 86 GT.
They work really well and I have not needed the quad shocks since they were installed years ago.
If you are interested in checking them out they are being manufactured again under a new name.
UMI Lift Bars
Old 01-16-2012, 02:57 PM   #28
OG86GT's Avatar
UMI Lift Bars
Thanks and by any chance do u know a place for decent prices on nitrous kits? So far I've checked american muscle who has a kit for 575 plus 190 for bottle warmer
Old 01-16-2012, 03:43 PM   #29
Re: Track time!!
Check with our site Supporters/Vendors
If you have no luck with those, maybe check Jegs and Summit Racing.
Old 01-18-2012, 04:04 PM   #30
OG86GT's Avatar
I'm liking the zex kit from american muscle and they have every accessory possible
KCIR to close? i973eat1 Regional Mustang Discussion 2 11-06-2011 01:15 AM
slower track time after mods?!? frank07stanggt 2005-2010 Mustang GT 12 10-20-2011 10:29 AM
First time racing at the track... skyline247 At the Track 14 10-06-2011 09:55 PM
Track time with the Kenne bell mazayu 1996-2004 Mustang GT 9 10-05-2011 07:55 PM
07:13 PM
