Egr info - Mustang Evolution
Old 01-13-2012, 07:48 PM   #1
Matt5.0's Avatar
Egr info
Does anyone know where the egr vacuum solenoid and egr valve pressure sensor are located on a 94 gt. 5.0.
Matt5.0 is offline   Reply With Quote
Old 01-13-2012, 08:16 PM   #2
Lapida's Avatar
On the elbow attached between the upper intake manifold and throttle body.
Lapida is offline   Reply With Quote
Old 01-13-2012, 08:40 PM   #3
Matt5.0's Avatar
Yeah that is the egr valve i need the sensor and solenoid, i think what i am looking for may be behind the splash shield but not 100% sure. Any other help would be great
Old 01-13-2012, 08:44 PM   #4
Matt5.0's Avatar
That is the egr valve what i am looking for is in following pica
ID:	38046   Click image for larger version
Old 01-14-2012, 04:31 AM   #5
Re: Egr info
I believe they are located in the passenger's side rear corner of the engine bay.
Maybe behind the inner fender.
Old 01-14-2012, 05:33 AM   #6
Lapida's Avatar
Like Trojan said, passenger's inner fender.
Old 01-14-2012, 06:23 AM   #7
If u have the egr valve caped off do I still need all that in the fender or can I unhook all that.
Robbie94gt is offline   Reply With Quote
Old 01-14-2012, 09:56 AM   #8
Re: Egr info
Not sure. Since there are wiring connectors attached to some of them it may cause issues with your ECU.
Usually when removing the EGR, most people use an EGR Eliminator (Search the forums for more info on them.) to fool the ECU into thinking it is still there so it does not throw a CEL.
The wiring connections and a vacuum source to those parts may be necessary in doing that.
Old 01-14-2012, 07:24 PM   #9
Ok I'll check into thst eliminator for the egr vavle. And also have u ever seen a fuel pressure gauge drop bout 4 psi when u rev the motor up to bout 2500 rpms
Old 01-15-2012, 12:42 PM   #10
Re: Egr info
From idle pressure? Yes
Old 01-15-2012, 12:48 PM   #11
So it's normal for your pressure to drop when u rev it at idle?
Old 01-15-2012, 01:26 PM   #12
Re: Egr info
Yes it is.
Just like when you turn on a faucet or open a valve on any pressurized container.
Old 01-15-2012, 01:47 PM   #13
Ok I was just wandering cuz my car has devolped a miss only if I push down on the gas pedel more thsn half throttle when I driving it. When I rev it it does fine . Almost like a hicup. Don't do it if I'm easy on it. Amd I've done put a new tune up. New fuel filter.new distubitor Checked the voltages on the maf and tps. Haven't tried the fuel pump or oxygen sensors but ain't getting no codes. It seems like a fuel problem to me. Cause it seems like if I try to give it alot of gas at one time it won't take it and miss. But I guess i'm going to try a new pump when I get alittle extra money. But the egr is capped off from the header but it missed b4 I capped it off so I'm just runnig out of things to try. But hopefully the pump will take care of it
Old 01-15-2012, 01:52 PM   #14
could be a spark issue as well.new plugs and coil might help as well.
Old 01-15-2012, 02:04 PM   #15
thansk for your input Ok Im goinh to try a new coil. It has new plugs and wires. It usually misses more after it's warmed up to operating temp. If that tells ya anythnh
Old 01-15-2012, 02:09 PM   #16
New coil IMO always helps with throttle response and they are relatively cheap.should be part of a tune up if it is old.AutoZone sells msd.
Old 01-15-2012, 02:11 PM   #17
Alright i guess I'm goinh to get a coil and fuel pump and I'll let y'all know how it turns out
Old 01-15-2012, 02:19 PM   #18
Cool.hope it helps.
Egr valve Matt5.0 1979-1995 Mustang GT 5 01-02-2012 09:15 PM
Egr bypassed Travis B 1979-1995 Mustang GT 1 11-22-2011 08:28 PM
EGR troubleshooting? Nate98stang 1996-2004 Mustang GT 3 11-04-2011 01:23 PM
Egr valve and evr tbonestang 1979-1995 Mustang GT 18 08-03-2011 04:59 PM
egr hole? workmail21 1979-1995 Mustang GT 1 07-26-2011 08:19 AM
09:32 PM
