Engin !!!HELP!!! - Mustang Evolution
Old 01-14-2012, 02:02 AM   #1
94Fivepoint0's Avatar
Engin !!!HELP!!!
I just had the water pump and heads cleaned on my 94 gt by the local mechanic,
The thing is that I got the car back but when I step on the ga it lags.....
The car takes a while to pick up speed and the rpm seems to be hi at 200000
I can't even burn put like I use too...
If anyone has a clue on what to do I would
Love the help.... Thanks
94Fivepoint0 is offline   Reply With Quote
Old 01-14-2012, 04:20 AM   #2
Re: Engin !!!HELP!!!
Do you mean that he flushed the cooling system?
Maybe he knocked loose a wiring connection on the engine?
Check all of your connections, especially the TPS, IAC, MAF & AIT.
Old 01-22-2012, 01:04 AM   #3
I checked and replaced the AIC...
Can it be the clutch that makes it loose hp? I also replaced the file pump do to very low pressure
And the water pump was replaced the mechanic also cleaned the heads.
I tried to scan for the problem but the scanner does not pick the car up.?
Old 01-22-2012, 08:08 AM   #4
It sounds like u tried hooking the scanner up to the port under the dash your mechanic should know that. . That's if it didn't reconize anything. That's for obd2 computer system. That's for 1996 models and up. Your hookup is is under the hood. And it is obd1 code system. It's on the passenger side close to firewall. If u don't know much about the about obd1 u should do a little research on it. U actually can use a short piece of wire or a test light to run your codes for obd1. If u don't have a scanner for it.
Robbie94gt is offline   Reply With Quote
02:21 PM
