T-5 questions - Mustang Evolution
Old 01-14-2012, 07:48 AM   #1
captain78's Avatar
T-5 questions
Stock t-5. When I shift it's really hard to get into reverse and grinds a little going into a couple of gears feels as if I'm not push clutch all the way down but it's to the floor. Is this a adjustment issue or change the clutch issue. Please don't let it be change the tranny issue
captain78 is offline   Reply With Quote
Old 01-14-2012, 01:22 PM   #2
Re: T-5 questions
Probably a clutch adjustment issue.
Hook your foot under the clutch pedal and lift it up as far as you can.If you hear a series of clicks, then it needed adjusting.
If you don't hear anything and there is no change in your clutch, then you might need to install a firewall mounted clutch adjuster to make further adjustments.
If you need to install the firewall adjuster, then you should also consider replacing the clutch cable and quadrant.
There is also a clutch cable free play mod in the Useful Mustang Info thread you should consider doing to keep your throw out bearing from riding on the clutch pressure plate prongs.
Maximum Motorsports has the best cables and quadrants, visit their site and read about them to see what I mean.
Old 01-14-2012, 01:30 PM   #3
captain78's Avatar
Thanx will do
Old 03-06-2012, 09:33 AM   #4
captain78's Avatar
Come to find out the synchronizers or shot in my tranny
Old 03-06-2012, 09:50 AM   #5
Re: T-5 questions
Put some manual trans info in the Useful Info thread.
One link is for a High Performance rebuild, 650 HP.
Old 03-06-2012, 10:23 AM   #6
captain78's Avatar
Cool I'll look it up
Old 03-06-2012, 10:40 AM   #7
Re: T-5 questions
It's the last post in that thread.
Old 03-06-2012, 10:56 AM   #8
captain78's Avatar
Just got done reading them just wish the Astros trans wouldn't cost more than the TKO
Old 03-06-2012, 11:05 AM   #9
Re: T-5 questions
Yeah, that's the problem with high performance parts like those.
You end up with more money in an old component than you would have spent just buying a complete new component.
Pretty impressive what they can do with a T-5 though.
I have a PDF on stock rebuilds somewhere on my PC if you need it.
Old 03-06-2012, 11:42 AM   #10
captain78's Avatar
I should be ok. But will keep that in mind if I need it.
2 questions on brakes. All4sho 1979-1995 Mustang GT 4 12-13-2011 09:45 AM
95 GT questions deadsp0t 1979-1995 Mustang GT 54 11-04-2011 02:16 PM
Tearing apart a 03 mustang.. many questions please inform. Black_Sunshine Pre-2005 V6 Mustang 1 09-15-2011 01:32 PM
Nitrous Questions Murdered_Stang 2005-2010 Mustang GT 2 07-19-2011 12:00 AM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
10:20 PM
