1987 Mustang GT 5.0: Huge Help Needed - Mustang Evolution
Old 01-14-2012, 01:40 PM   #1
Unhappy 1987 Mustang GT 5.0: Huge Help Needed
To start this off I will be posting to many, many forums my problem. First off,
Details Of Motor:
Block: 302 bored 30 over
Crank: Stock
Pistons: Stock
Cam: B-303
Heads: Aluminum Gt-40 SVO
Rockers: Stock
Intake Lower: Gt-40
Intake Upper: Gt-40
EGR Spacer: 70mm
Throttle Body: 70mm
Intake Tube: Aftermarket Cold Air
Mass Air Meter Housing: 70mm
Headers: BBK Shorty 3/4
Cats: None
Exhaust Pipe: Off-Road H-Pipe
Mufflers: Flowmaster
End Tips: Dumps
Computer: ’93 A9L Mass Air Computer
Fuel: Stock Fuel Pump
Injectors: Stock 19lb
Fuel Lines and Tank: Stock
Problem(s):
First two problems interchange but first problem is more present:
1) Surging Idle ( 1500 rpms to shut off ):
When cruising at rpms higher then 1500, letting of the gas and pushing the clucth, the car’s idle will drop till it cuts off.
If cruising at the same rpm as above then slowing the car down to where it should it, then 50% of the time, it will stay there or it may surge till it cuts off.
If at idle the car will idle if cold but after a few minutes the car will start to surge till it cuts off.
Parts Tested To Find Problem:
Throttle Postion Sensor: Set to .97 Volts
Parts Tested But Not Sure If Bad:
Stock Mass Air Sensor: 12 Volts to + and - Wire, 12 volts to 3rd wire,
Signal Wire is the problem wire. It is suppose to stay at around the same idle at idle. It changes erratically at idle and when the throttle is pushed. Please give opinion.
Vaccum Lines:
All visible vaccum lines have been checked with cleaner to check for vaccum leaks. Advise if all lines should just be replaced.
Parts Replaced To Fix Problem:
Idle Air Control
2) Hanging Idle:
When starting the vehicle it will hang to around 2000 rpms then drop slowly to 1100 rpms.
As I push the throttle to gain speed then shift, it stays at that rpm for 2 to 3 seconds then drops to around 1100 rpms.
Vaccum Lines:
Idle Air Control
3) Whining/Whistle Noise:
Vehicle as a whining/whistle noise coming from the engine compartment at idle and cruise. Noise does increase as rpms increase. All gaskets and suppected hoses have been sprayed for leaks.
Vaccum Lines/Gaskets
Vaccum Lines:
Not the Problem:
Pulleys
My Note:
Please post on the thread or send me an email at stj_1993@yahoo.com. I need help with this problem really bad. This is my daily driver and I have no clue what else to do. I need you to list what you think I should replace, test, or do to find the answer to my problem(s). Thank you so much everyone.
Johnson is offline   Reply With Quote
Old 01-14-2012, 01:59 PM   #2
did these problems occur after your upgrades? also did you check your intake manifold for vacuum leak or just the lines?i would say if your lines look ok then they dont need replaced:no holes,kinks collapsing etc.
this is located in the stickies. http://www.stangnet.com/mustang-foru...cklist.698148/
Old 01-14-2012, 02:17 PM   #3
Re: 1987 Mustang GT 5.0: Huge Help Needed
The whistle could be in your intake tract or it could be a vacuum leak in your intake itself or other vacuum powered accessories.
There are more possibilities for vacuum leaks than just the hoses.
Do you have a Chilton's or Haynes manual?
You need to follow the procedure in one of those to properly set the idle.
Have you checked and set the timing?
You mentioned pulleys, are they under drive pulleys?
If they are and you have not upgraded your alternator, then low voltage could be part of your problem.
Old 01-14-2012, 02:31 PM   #4
To dreamstang:
Problems happened after cam and mass air system was installed.
I sprayed the intake for signs of leaks and did not find any.
Lines look ok from what I can see.
To Trojan Horse:
All the intake tract has been sprayed.
No I do not have a manual.
Timing is 13 degrees.
No underdrive pulleys just stock P/S, A/C, Crank, W/P, and Alternator pulleys.
Old 01-14-2012, 02:40 PM   #5
13 should be ok as long as there is no signs of detonation.i would try setting the idle with the proper technique like TH described.you may find that in the stickies also.you may just need to get a tune.
Old 01-14-2012, 08:11 PM   #6
To dreamstang:
Timing is good. No detonation.
I set the timing by using an online step by step process.
If you could check the part about the MAF Sensor reading. Should I get a new MAF and get a tune?
Old 01-14-2012, 09:34 PM   #7
mystang50's Avatar
What exactly do u mean by upgrading ur alt.?? For u/d pulleys
Old 01-14-2012, 09:42 PM   #8
Cobrarunnin9s's Avatar
What brand is the mass air? And any reading on the signal wire for the mass air over 5 v is bad, your mass air is saturated..
Cobrarunnin9s is offline   Reply With Quote
Old 01-14-2012, 11:23 PM   #9
To Cobrarunnin9s:
Professional Products 70mm MAF Housing
Whenever the car is at idle it jumps around haywire like.
Old 01-14-2012, 11:50 PM   #10
If you have the stock one still, put it back on and see what happens. If that was the problem you should be able to
replace both with a meter from from the lightning it's a 90 mm piece and it's factory
Old 01-15-2012, 12:16 AM   #11
I don’t have it anymore. I think the size is ok. I think I just need a new mass air sensor.
Old 01-15-2012, 12:36 PM   #12
Under drive pulleys are infamous for causing charging problems because they do not spin the stock alternators (pre- 94-95) fast enough to keep the battery charged and the voltage up at idle.
Low voltage in your electrical system can cause all sorts of weird problems.
Old 01-15-2012, 12:46 PM   #13
stupid u/d pulleys! agreed
Old 01-15-2012, 01:20 PM   #14
mystang50's Avatar
What bout 9495 I have u/d and mine drops to can I "upgrade" a alt for my 95?
Old 01-15-2012, 01:32 PM   #15
You can, but the 3G in your car should be up to the task.
Maybe you should have it tested?
I ended up buying a 200 Amp alternator for my 86 GT, because I am going to be running so many electrical mods on it.
Electric fan, electric water pump, MSD ignition.....
Old 01-15-2012, 01:51 PM   #16
mystang50's Avatar
Test said it was good
Old 01-15-2012, 01:57 PM   #17
how did u test it?with u/d pulleys the alternator can be in perfect shape but still not charge efficiently.the best way is to use a volt meter on the alt leads while running.it should be at least 12 volts at idle and up to 14 ish with throttle.
Old 01-15-2012, 02:09 PM   #18
mystang50's Avatar
I tested it at auto zone it goes low with headlights on and when fan comes on, and when I go to a stop cause idle drops
Old 01-15-2012, 02:19 PM   #19
If they tested on the car that should be ok.but testing off the car will not tell how it charges with your u/d pulleys.that's why I said the best way is the volt meter.
Old 01-15-2012, 02:35 PM   #20
Did they test it with the U/D pulley and at what RPM did they test?
When you first start the car, hook up a voltmeter and see if the voltage jumps up to around 14.5 volts.
Then turn the car off, disconnect the battery cables and test your battery voltage.
The voltage on the battery should be at 12.5 volts or slightly more.
Any less than 12.5 volts and it means that the battery needs to be charged or it is defective.
Old 01-15-2012, 06:27 PM   #21
mystang50's Avatar
Yes with u/d pulleys and it was at idle
Old 01-15-2012, 07:53 PM   #22
I did not get to the car today with my 11 hour work day but tomorrow afternoon I will be working on it. I will post soon.
Old 01-17-2012, 10:13 PM   #23
Mass Air Flow tested good. I had a bad volt meter. So if TPS, IAC, and MAF good. Now I have another computer on the way. A new computer and vaccum leak to check.
Old 01-18-2012, 08:12 AM   #24
Stang.racr's Avatar
Forgive me if I missed a post but have you had a dyno tune yet, just kinda curious cause you have a pretty good bit of performance parts so I was wondering if it's been on a wide band or anything. Not to keep adding to your frustration but I've seen you have already checked a lot of parts, I've never had this issue but depending on when you have this issue it could be something like a temp control sensor maybe?
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 01-18-2012, 08:19 PM   #25
Never looked at the temp control sensor. I am taking the upper intake over in a couple days. And no I have never put it on a dyno. I have never tuned it or anything. Think that might help?
1987 mustang
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
02:06 PM
