C&L cold air intake - Mustang Evolution
Old 01-14-2012, 07:53 PM   #1
jwhayne0001's Avatar
C&L cold air intake
i was shopping american muscle for the cold air intake for my car, and then looked to cj pony parts, and they list 3 diffrent ones, depending on injector size, which mine has 24lb stock injectors, and american muscle only lists one, will it still work for me? trying to stay a loyal american muscle customer!
jwhayne0001 is offline   Reply With Quote
Old 01-14-2012, 08:09 PM   #2
WhiteCobra94's Avatar
I don't know much about C&L but I went with granatelli 75mm mass air sensors with JLT's cold air intake which is a 4in pipe necked down to 75mm
Old 01-15-2012, 01:06 PM   #3
Re: C&L cold air intake
C&L is a good brand name as far as I have read and heard.
Injector size should not have anything to do with a CAI, unless you are buying a MAF too.
Make sure whichever one you decide to order will fit your MAF connection and air filter.
You could also check with LRS, they are a site supporter too.
AFM's Power Pipe is another good CAI worth taking a look at.
Old 01-15-2012, 03:02 PM   #4
AM's c&l states it comes with a 76mm maf housing and per instructions you just slide the factory mafs and it comes with a filter suppose I'll order it and find out lol
Old 01-15-2012, 03:35 PM   #5
Oh, I see.
It probably won't work with aftermarket MAFs' then, which is why they said it depends on injector size.
Old 01-15-2012, 04:18 PM   #6
04machazblue's Avatar
Oh, I see.
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 01-15-2012, 04:46 PM   #7
I should have said, "aftermarket MAF's circuit board and sensor."
cold air intake
Best cold air intake? Pstang5 2011-2014 V6 Mustang 11 12-27-2011 07:47 AM
Intake Suggestions..... Srohda 2011-2014 Mustang GT 42 09-19-2011 03:56 PM
Vacuum lines coming from passenger fender well.? Otlaw80 1979-1995 Mustang GT 3 08-15-2011 07:01 AM
05:54 PM
