Aftermarket part ?'s - Mustang Evolution
Old 01-15-2012, 03:53 PM   #1
Swangin_Stangs's Avatar
So I have the BBK SSI-R intake manifold with the BBK cold air intake, and BBK 75mm Throttle body with EGR spacer, my question is I am also upgrading my fuel injectors to trick flow 24lb injectors what size mass air meter do I need to get (also gonna be BBK as well) on a 86 mustang 5.0 notchback.
Swangin_Stangs is offline   Reply With Quote
Old 01-15-2012, 04:16 PM   #2
04machazblue's Avatar
U get get a c&l mass air meter tube with a test tube for 24lbers
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 01-15-2012, 05:15 PM   #3
Re: Aftermarket part ?'s
You do know that the BBK SSI-R is aimed at supercharged and high RPM 5.0 engines don't you? Mustang 50 Article
Just asking because you will likely lose most of your low end power with it.
You will need a MAF calibrated for the 24 lb. injectors like 04machazblue said.
I would recommend you to take a look at the ABACO MAF.
You can reprogram them for any injector size you want to use from your desktop or laptop PC, so you never have to change out or send in your MAF if you want to make injector changes.
Aftermarket Shifters 2011CS 2011-2014 Mustang GT 31 12-09-2011 11:33 PM
What is this part? AniBalian 2005-2010 Mustang GT 5 12-06-2011 10:58 AM
aftermarket spoiler ideas shsfresh87 Mustang Paint, Appearance & Detailing 10 11-10-2011 11:39 AM
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
08:26 PM
