86 5.0L question - Mustang Evolution
Old 01-15-2012, 08:18 PM   #1
OG86GT's Avatar
86 5.0L question
Is there any pair of aluminum heads u can put on an 86 5.0 without notched pistons?
OG86GT is offline   Reply With Quote
Old 01-15-2012, 08:29 PM   #2
im no expert but i believe most aftermarket heads dont require knotched pistons.whats gonna determine if you need knotched pistons is your cam,roller rockers, etc.but the best thing to do is check piston to valve clreance when installing the heads.
Old 01-15-2012, 08:53 PM   #3
OG86GT's Avatar
I just know edelbrock and afr say if u have an 86 5.0 pistons must be notched for valve clearance
Old 01-15-2012, 08:55 PM   #4
hmmm....never really looked into it for the 86.
Old 01-15-2012, 08:55 PM   #5
Re: 86 5.0L question
Read up on the Trick Flow heads.I think they have a set that will let you run larger cams without having to have the notched pistons.
Even if they do you are always much better off to check the clearance before the final installation just to be sure.
Old 01-15-2012, 09:41 PM   #6
OG86GT's Avatar
I just may. Or I may be convinced to lean towards nitrous until I get my hands on a 87-93 5.0L motor
Old 01-20-2012, 08:48 PM   #7
86 muscle's Avatar
Our 86 came with a flat top piston, no valve reliefs! That put and puts a serious damper on the heads and cam we can use. I ran an E303 in mine with problem, however on stock heads. If you change then out the best way to tell if it will fit is to put Clay on the top of the piston, bolt the head on and cam and and spin it by hand, then take the heads off and see if you made contact with the piston it will be clear, however if you are that close, might as well forge the internals!
86 muscle is offline   Reply With Quote
Flowmaster question NuckChorris 2011-2014 Mustang GT 19 12-15-2011 04:26 AM
I got a question??? 94GTx306 1979-1995 Mustang GT 9 12-09-2011 04:06 PM
Exhaust question Codysmustang 1996-2004 Mustang GT 14 11-21-2011 09:11 PM
Kenne bell 2.6L question Ahmed ali khan 1996-2004 Mustang GT 4 11-14-2011 12:54 PM
Hellion Powered 2011 5.0L Mustang GT - DRAG STRIP VIDEO JohnnyMustang 2011-2014 Mustang GT 18 08-01-2011 12:29 PM
01:01 PM
