Lights Out; Any Ideas? - Mustang Evolution
Old 01-15-2012, 10:19 PM   #1
Mdavis1024's Avatar
91GT Vert. Headlights stay on for about 5 minutes, maybe less. Then the headlights go out. Markers stay on. Rear, dash lights, backup, high beams, and fog lights not affected.
I checked just about everything that I thought to check. Fuse, wiring, dash panel.
Bounce some stuff off me.
Mdavis1024 is offline   Reply With Quote
Old 01-15-2012, 10:26 PM   #2
Re: Lights Out; Any Ideas?
Sounds like the switch may be failing.
Old 01-15-2012, 10:26 PM   #3
Sometimes the switches go bad.also the wires on the back of the switches come loose sometimes.u need to get a wiring schematic and find where u are loosing power.
Old 01-15-2012, 10:27 PM   #4
Sounds like the dimmer switch may be failing.
Old 01-15-2012, 10:31 PM   #5
Mdavis1024's Avatar
Dimmer switch hmmmm. I never checked that.
Old 01-15-2012, 11:02 PM   #6
mystang50's Avatar
Yup I've gone threw 2 switches allready
Old 01-15-2012, 11:26 PM   #7
Fredfifty's Avatar
So your hi beams work?
Rest in Peace Edson Veloro
89 LX Coupe 5.0 - SOLD
91 GT Vert 5.0 -CURRENT
07 TBSS - CURRENT
Fredfifty is offline   Reply With Quote
Old 01-16-2012, 08:20 AM   #8
Mdavis1024's Avatar
My high beams still work, yes. It's just strange that my regular lights work then shut off after about 5 minutes.
Old 01-16-2012, 08:41 AM   #9
oh I know the problem is because is a ford thats your problem,,,just kidding is probebly the bulb it self the tin wire inside is wering off ready to go out sow is not making contac anymore
robertoortiz85 is offline   Reply With Quote
Old 01-16-2012, 09:10 AM   #10
The contacts in the dimmer switch are likely heating up whenever the lights are turned on.
After a few minutes they get hot enough to lose contact and the lights go out.
You might want to check your ground wires and see if there is a separate ground for the high and low beams, but I'd bet they use the same ground.
If they don't and each has its own ground then you may possibly have a grounding problem.
If the light can't get a good ground it could back feed through the system causing issues like you described.
Old 01-16-2012, 09:14 AM   #11
The "tungsten" filament in the bulbs could be broken and as it heats up it may move away from contact, but it is unlikely that both bulbs would do the same thing at the same time.
Old 01-16-2012, 09:17 AM   #12
deadsp0t's Avatar
My money is on the headlight switch. I've had similar crazy issues with an 86' 91' 95' 95'.. All four are fords all with crazy issues, all tied to the headlight switch solved by replacing it.
That's unimpressive
Old 01-16-2012, 11:45 AM   #13
mystang50's Avatar
Yes if I held them on...and TH is right talking bout the contacts
Old 01-16-2012, 11:47 AM   #14
Mdavis1024's Avatar
Im thinking the switch too because it started happening after I pulled the dash. (MAN I LOVE THIS PLACE). Getting to bounce things off you guys helps so much.
---------- Post added at 01:47 PM ---------- Previous post was at 01:46 PM ----------
Yes. I have to hold my hi's on too in order to get light when the lows go out.
Old 01-16-2012, 12:42 PM   #15
mystang50's Avatar
Light.
Yup. Replace the switch
Old 01-16-2012, 01:31 PM   #16
Mdavis1024's Avatar
Dang, okay. I'll try that and see if it works. Thanks for everyone's help.
Old 01-16-2012, 01:39 PM   #17
mystang50's Avatar
Yuupp its not hard and not that expensive
Old 01-16-2012, 04:17 PM   #18
try these relay diagram you will get better ground and power
Old 01-16-2012, 04:52 PM   #19
Mdavis1024's Avatar
Nice. Thanks.
fog lights mystang50 1979-1995 Mustang GT 11 11-30-2011 07:06 PM
tail lights.? mystang50 1979-1995 Mustang GT 5 10-09-2011 01:32 PM
Stay on running lights uh60facilitator Mustang Paint, Appearance & Detailing 0 08-17-2011 12:19 PM
Fog lights?? Holdempoker102 2005-2010 V6 Mustang 20 07-21-2011 07:56 PM
10:52 AM
