Car died ? - Mustang Evolution
Old 01-18-2012, 01:11 PM   #1
Cm644rodrigues's Avatar
Car died ?
My 87 died just now waiting for the tow to come. I was driving to school and Rpms dropped to zero and car died. The car will turn over good just wont start. So now im stuck. Cars been running great lately especially in the cold. I'm thinking a bad TFi anyone who may know different let me know wanna fix it ASAP. And is there a way to test for a bad TFi
Cm644rodrigues is offline   Reply With Quote
Old 01-18-2012, 01:39 PM   #2
Re: Car died ?
How to Test The TFI Module & Hall Sensor
Old 01-19-2012, 01:25 PM   #3
So do I have to replace the grey bolt in plug if it's bad or is the TGIF internal?
Old 01-19-2012, 01:47 PM   #4
93slowstang's Avatar
It's the grey module that you would replace.
Old 01-19-2012, 01:50 PM   #5
Cool think I have a few laying around
Old 01-19-2012, 10:15 PM   #6
94 Mustang GT's Avatar
Any luck yet? If it cranks check to see if you have fuel. Try to listen for the fuel pump if you can't hear it just spray some brake clean or something similar down the throttle body. If it starts and runs for a little you have a fuel issue. If that's not the case check spark.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 01-20-2012, 01:06 PM   #7
Check the tab and tad solenoids. when mine went out, they also fried my computer. Same symptoms.
Kjohnson1 is offline   Reply With Quote
Old 01-20-2012, 03:25 PM   #8
Re: Car died ?
Wow, how did they do that, short out?
If you are not using the smog pump and catalytic converters, you can disable the TAB/TAD solenoids.
To prevent the ECU from throwing a code you use these Resistors
For more information check out - TAD/TAB 1 & TAD/TAB 2
Old 01-20-2012, 04:01 PM   #9
I didn't test them after they failed. But im sure they had to short out. I did trace the wires for the TAB and TAD and found they were not fused. I fried a total of two computers before I found the problem. I had a guy with a Ford Breakout box come over and he found the problem. After i took the computers apart, i could see where the exact pin for the TAB and TAD had burned the computer board.
Same car as the post starter too. 1987 GT. I was driving and the car just shut down in the middle of the road.
Old 01-20-2012, 04:17 PM   #10
Re: Car died ?
Thank you!
That's more info I can add to my ever growing knowledge base.
How To: Plasti Dip Your Car (In Depth, 6 pages worth of Microsoft Word) Topless04GT Mustang Paint, Appearance & Detailing 318 05-17-2017 12:40 PM
Horrible stangs we've all seen em Dgibson Pictures and Videos 225 05-15-2012 09:29 PM
Car show in Queen Creek, AZ Loraco Regional Mustang Discussion 1 12-07-2011 10:58 AM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
Almost died Z06 eater 1979-1995 Mustang GT 19 07-14-2011 10:16 PM
01:46 PM
