Need some of your expert opinions! - Mustang Evolution
Old 01-18-2012, 04:04 PM   #1
89Saleen141's Avatar
I've heard that adding a camshaft with the stock E7 heads hurts the performance more than helping it. If you have stock heads but full intake, would this still be true? I have a full exhaust and full intake with gears, advanced timing, and underdrive pullies.
89Saleen141 is offline   Reply With Quote
Old 01-18-2012, 04:49 PM   #2
Re: Need some of your expert opinions!
It will if you exceed the flow capabilities of the heads with a cam that has too much lift or duration.
As long as you choose a cam to work with what you have you should be ok.
Use the CamQuest tool to see what cam specs would work best for you.
Old 01-18-2012, 10:49 PM   #3
Thanks man, you've helped a lot. I just don't know what to do next after I installed the full intake. I don't have enough cash at the moment for good cylinder heads. I looked at those AFR's you mentioned and they seem like the best bet, but they are pretty pricey.
Old 01-19-2012, 12:52 PM   #4
Just start searching for a used set. Eventually you will run across a good deal at the most opportune moment.
Trick flow opinions Tj88mustang 1979-1995 Mustang GT 11 12-04-2011 02:46 PM
About to get stripes painted on! Need opinions! Las0mbra Mustang Paint, Appearance & Detailing 8 10-21-2011 01:18 AM
opinions on clone cars 93cobradude General Mustang Discussion 15 09-03-2011 09:07 AM
opinions on color for 88 fox 04TRV6 1979-1995 Mustang GT 39 07-08-2011 12:30 AM
08:24 AM
