ok i have a 95 gt 5.0 getting codes 311 and 314 - Mustang Evolution
Old 01-19-2012, 03:07 PM   #1
this says that the air system inoperative during koer (bank on number 1 and 2 dual heated oxy. sensor left and right side what does this mean do i need to replace them i just got bbk shorty headers and full pypes exhuast system i put the same o2 sensors back on it plz help me asap
durtyred69 is offline   Reply With Quote
Old 01-19-2012, 06:22 PM   #2
Re: ok i have a 95 gt 5.0 getting codes 311 and 314
If the sensors were very old it is possible to damage them internally during R&R.
Sounds like you need some new ones.
Old 01-19-2012, 08:08 PM   #3
Ok I just replaced my o2 sensors and got a half mile down the street it stopped code 211 I have a msd distributor I replaced the stock one because of this same issue
Old 01-19-2012, 08:38 PM   #4
Code 211 is the PIP Sensor (Pickup Coil) in the distributor I believe.
The PIP is responsible for base spark and injector timing from what I have read.
Sounds like you might need a new one, but I'd double check the distributor wiring first to ensure there are no broken or disconnected wires.
PIP Sensor Replacement
Old 01-19-2012, 08:48 PM   #5
is it true that my problem maybe that i have a msd distubtor and the fact that i don't have the ignition box could cause this alot some one just mention that to me i dont just thought i mentioned it here
Old 01-19-2012, 08:58 PM   #6
It depends on which MSD distributor you have.
Some are made to work with the factory electronics, the others are not.
Look up the model number you have and see what it requires.
08:37 AM
