Getting away from E303 cam... - Mustang Evolution
Old 01-20-2012, 06:22 PM   #1
I would really like to change my e303 cam to a lunati cam but have a few questions. First of all has anyone ever run a lunati voodoo cam on a stock bottom end 302? Can it be done? I'm wondering if I could run the smallest voodoo cam with my trickflow twisted wedge heads.
I am also interested to know if I must replace my roller rockers and lifters with a cam change. Car was built about 20k miles ago and the e cam is a little boring with its narrow power band and I want a cam with more low and midrange torque. Any suggestions and help are appreciated, whether it's recommending a cam itself or on what I'll need to replace when swapping cams, thanks.
Beastynotch is offline   Reply With Quote
Old 01-20-2012, 06:45 PM   #2
captain78's Avatar
I have a luniti voodoo cam in my 302 stock bottom in with AFR heads edlebrock intake and a 650cfm edlebrock carb. In my 77 runs great I love it I'm not running the roller cam tho. 1.6 rockers. And the voodoo is far from the smallest they got. Hooker long tubes 3in pipe to the warlock mufflers and 3 in dumps. Sounds and lopes great running smooth all the way through. I Also have 3:90 gears and a C4 with 2500 stall. I love my voodoo. But on my 90 GT. I'm looking at either a comp cam custom or f303. With stock bottom with my afr heads 1.6 rockers. And debating S/C
captain78 is offline   Reply With Quote
Old 01-20-2012, 06:46 PM   #3
Re: Getting away from E303 cam...
Is the Voodoo cam even a roller cam?
Go to CamQuest and input your engine specs.
It will help you choose the correct cam for the mods you have.
Old 01-20-2012, 06:49 PM   #4
captain78's Avatar
I haven't seen a roller voodoo hince why I'm goin with another. But hey if you find one let me know
Old 01-20-2012, 07:01 PM   #5
Yeah the Lunati website has a line of hydraulic roller tappet voodoo cams for 302/351w. I know the voodoo cam isn't their smallest cam, I was saying that I would want to run their smallest voodoo cam in my setup because I wanna avoid changing/altering pistons and/or valve springs and stuff. The voodoo 61010 cam has an awesome power band and torque curve and that's what I'm looking to get back. The e303 cam just doesn't have enough low end torque for me, power really doesn't come on until around 2700-3200 rpms.
Old 01-20-2012, 07:01 PM   #6
I looked, they are all flat tappet that I found.
I sure wouldn't go backwards and install one in a roller cam engine.
EDIT: I was in the wrong area, found them here - Voodoo Hydraulic Roller
Old 01-20-2012, 07:26 PM   #7
You should probably stay at or under .500 lift to ensure clearance.
The 601010 has .541/.549 lift which is close to the X303 Ford cam's lift.
If you decide to go with it a piston/valve clearance check might save you some grief.
Old 01-23-2012, 08:48 AM   #8
If I change from my e303 cam to a different cam will I need to change roller rockers again or just lifters? I've already got 1.6 roller rockers now so if there is no benefit to putting new ones on I'd just assume save the money.
Old 01-23-2012, 08:58 AM   #9
Just the lifters, however inspect the RR arms to ensure there are no flat spots on the rollers or other damage.
Old 01-23-2012, 09:49 AM   #10
stampde's Avatar
+1+1+1+1+1
2011 GT Auto
Cam help NateNasty 1979-1995 Mustang GT 3 01-13-2012 06:07 PM
cam gear spacer duffeycycles Classic Mustangs 2 12-03-2011 08:45 PM
Rebuilt aoed, cam question Schlahty 1996-2004 Mustang GT 0 11-10-2011 02:11 PM
Will GT40 Heads Handle A Big Cam?? 90Stang_5.0 1979-1995 Mustang GT 27 11-02-2011 03:12 AM
Cam Jesse Bach General Car Discussion 2 08-01-2011 01:37 PM
10:27 AM
