Procharger or 347?? 94 GT - Mustang Evolution
Old 01-21-2012, 01:54 PM   #1
cgarray17's Avatar
Like it says I'm having a hard time desiding what I want to do. Option 1.. Procharger with sporting mods and tune around 5k total. Option B... DSS 347 long block AFR 185 heads TF track heat intake with there lvl 20 block package(fully forged rotating acembly, main support system, ext) around $7600 total I'm assuming. My curent 302 has the track heat intake on it with full exhaust headers back with around 117k miles and is not abused and still runs fine. Just I am leaning to the procharger now and maybe a new motor next year just don't know how long the stock 302 might hold together with 11psi. Any input would be great as to what people have done in either rout and what kind of power/ reliability they made with similar setups thanks!!!
Cody
cgarray17 is offline   Reply With Quote
Old 01-21-2012, 02:08 PM   #2
OG86GT's Avatar
Cody
My dad had a stock 302 block with tf intake, heads, e303 cam. A bd10 powerdyne running 9 psi witb #42 injectors and he made 500hp. Ran it for 3 years before a lifter collapsed
OG86GT is offline   Reply With Quote
Old 01-21-2012, 04:47 PM   #3
cgarray17's Avatar
Re: Procharger or 347?? 94 GT
Wow nice
Old 01-21-2012, 06:37 PM   #4
WhiteCobra94's Avatar
DSS has a entry level 331 & 347 forged stroked shortblock for around $2000-$2,200 fully assembled with new AFR heads and a good intake (600-$700 intake) that's roughly around $4,500 , save the procharger for later so you don't do it twice!!!!
Old 01-21-2012, 07:04 PM   #5
Agreed.
You should use the Main Support System anyways if you are going with forced induction and I would also put the Valley Girdle Pro on it to further strengthen the block.
Old 01-21-2012, 07:58 PM   #6
Brett Greene's Avatar
Cody
My friend you h e good taste in mods/cars. But you need guidance for sure. Deff go with the built 347. You can't go wrong with a good NA motor. Then put the procharger on the motor. I have this exact build nearly in my 95 and I make awesome power and it's very very reliable. If you have any questions do not hesitate to ask me. I been down this road before. It's time
Consuming and lots of money to be spent. But you will end up with one wicked ride that will smoke anything you meet on the street.
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 01-21-2012, 09:56 PM   #7
cgarray17's Avatar
Well if I go 347 now then unless I go dissed pistons I can't go blower later? Because if I get the 347 in the spring it would be a while before I could get the blower. But also my goal is a nice DD so maybe a nice 347 is all I need?? Anyone know what kind of power a 347 with AFR 185 and a decent cam might make??
Old 01-21-2012, 10:00 PM   #8
Well my brother in-laws 91 lx had a forged 347 stroker DSS block, AFR 205 heads, Holley system max intake he's at 423rwhp
Old 01-24-2012, 07:50 AM   #9
cgarray17's Avatar
Nice do u know what cam he is running and injector size?? I was thinking of using 36 lb injectors on almost same build just AFR 185 not 205.
94 GT Convertible
Current- Stock long block 118k, MAC CAI, 75mm Pro M MAF, PP 70mm TB,BBK shorties,BBK O/R H, Magnaflow catback, KING cobra clutch, 3.73 Gears
Soon to be Vortech blown with a built 306 Numbers and times to follow!!!
Old 01-24-2012, 08:32 AM   #10
Right now he has 42lb injectors but its setup for nitrous, not sure what his CAM is but it is a high lift, I have a video of the car but I can't figure out how to upload the video besides using YouTube!!
Old 01-24-2012, 08:55 AM   #11
cgarray17's Avatar
Ya I'm hoping for upper 300s with the AFR185 and a good street able cam as its my summer dd and don't want something that's going to be a pain if any kind of trafic u know a fun reliable motor I mean I look at it as I'm at probably 200 rwhp with my curent mods so anything 300 and up rwhp would be sick!!
94 GT Convertible
Old 01-24-2012, 09:28 AM   #12
Well with a 347 stroker you will definitely be in mid to upper 300rwhp range
Old 01-24-2012, 10:21 AM   #13
cgarray17's Avatar
I know I can't wait to feel the new power, the highest hp stang iv been in is my friends trick flow hci 306 and that only dynoed at 305rwhp and he just broke the 12s mark in 1/4
94 GT Convertible
Old 01-24-2012, 10:38 AM   #14
generally building the motor to take a supercharger in the future works out good
Old 01-24-2012, 10:58 AM   #15
cgarray17's Avatar
Well if I build it with dished pistons how much am I going to sacrifice untill I get the blower which might be another winter away from happening??
Old 01-24-2012, 02:16 PM   #16
captain78's Avatar
Well I'm looking into a 331 from frpp built with the boss block for extra support. And might put SC on it so someone answer his question on the dished pistons. And I'm prolly either goin with a comp cam or f303 cam possibly. With afr heads. Holly systemax intake with 30lb injectors. FYI just the boss 331 is almost $5000. For a short block. And 331 instead of 347 just for extra meat on cylinder walls. Just incase something happens.
captain78 is offline   Reply With Quote
Old 01-24-2012, 02:29 PM   #17
The dished pistons are just to lower the compression ratio.as long as your not more than 9-1 you will be ok.it is still a good idea to run forged pistons with a s/c.
Old 01-24-2012, 05:08 PM   #18
cgarray17's Avatar
Well a 347 flat top piston will likely be 10.5-1 so I would not be able to run boost safely unless using dish pistons.
94 GT Convertible
Old 01-24-2012, 05:30 PM   #19
You can still run a SC, but your "safe" boost level will be lower.
See the links below to pages with information about supercharging.
Procharger FAQ's
Kenne Bell FAQs
Jegs SC Basics
Old 01-24-2012, 05:47 PM   #20
If it were my decission id split the diffrence and build a 331 with full forged inturnals and 9/1 or8.5/1 compression put a blowzilla 2.2 kb on top and have fun with about 600hp now if u cant afford the blower and the motor build the 331 up with 9/1 dished pistons and use the ford racing f-303 cam this is a good cam for blower applacations but is still very nice for n/a applacations with 8/1 compression pistons 14psi on the blower should be ok with 8.5/1 id go 10-12 psi and 9/1 prolly 8-10 psi on the blower
Hawk is offline   Reply With Quote
Old 01-25-2012, 05:32 PM   #21
cgarray17's Avatar
Well after looking around I found this FORD RACING BOSS 302 - 345 HP PERFORMANCE CRATE ENGINE ASSEMBLY -- M-6007-X302B and am really considering it. It's $150 more then the dss 347 I was looking at and it has a boss block and fully forged internals, so I could get this now and then put a procharger on it next winter and have a sweet DD that's also reliable.
Old 01-25-2012, 05:48 PM   #22
Nice.that should do the trick.
Old 01-25-2012, 06:00 PM   #23
captain78's Avatar
That's what I was looking at too
Old 01-25-2012, 06:40 PM   #24
That will definitely do the trick.
That combo should be able to handle almost anything you wish to throw at it.
Old 01-25-2012, 09:20 PM   #25
cgarray17's Avatar
And with free shipping I'm also saving a boat load plus the 347 dident come with oil pan pump ext.. So will through my track heat intake on it with some 30lb injectors and have some fun this summer!!!!
my 04 gt, vs 03 cobra and 2011 mustang gt secomejia 1996-2004 Mustang GT 57 01-04-2012 08:07 AM
Will Stock 1998 GT H-Pipe Fit My 2003 GT? Brent 1996-2004 Mustang GT 5 10-12-2011 08:44 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
03:41 PM
