87 foxbody - Mustang Evolution
Old 01-21-2012, 05:10 PM   #1
Volfireman420's Avatar
87 foxbody
I have a 87 gt with a 5.0 in it and getting gas in the oil any suggestions to fix the problem
Volfireman420 is offline   Reply With Quote
Old 01-21-2012, 05:34 PM   #2
Sounds like one of the injectors is broken. Possibly the pintle broke on one.
Kjohnson1 is offline   Reply With Quote
Old 01-21-2012, 05:40 PM   #3
Thanks I have been told it could be a fuel pressure regulator or a intake gasket im open to any suggestions
Old 01-21-2012, 06:58 PM   #4
Re: 87 foxbody
It isn't the intake gasket.
You have a number of possibilities:
1. Broken or stuck fuel injector(s).
2. Engine is badly out of tune with a way rich fuel mixture.
3. The diaphragm on your fuel pressure regulator has a pin hole in it.
4. If adjustable your fuel pressure regulator has the pressure set way to high.
See the RJM Injection Tech link in my Useful Mustang Info sticky thread for a fuel injector service kit if you want to start with them. It comes with all of the filters, O-rings and caps for an 8cylinder engine for $20.
You can rig up a momentary 12 volt switch and a injector pigtail plug to test the injectors and see if they are opening and closing. Just hit the switch and blow through them with some compressed air or a rubber hose slipped over the injector and your mouth. You can also clean them out with some carb cleaner while you are doing that. Just don't get any in your mouth.
Old 01-21-2012, 08:34 PM   #5
Thanks trogan horse
Old 01-21-2012, 08:45 PM   #6
Re: 87 foxbody
Thanks trogan horse
You're welcome & good luck with your issues.
foxbody
My foxbody Turbodave5.0 New Member Introductions & Greetings 10 12-01-2011 04:37 AM
Getting a new to me foxbody!!!! MC770 1979-1995 Mustang GT 43 10-25-2011 03:01 PM
New foxbody 04machazblue 1979-1995 Mustang GT 23 10-13-2011 08:34 AM
Mach 1000 in Foxbody SleepingStang Mustang Audio & Video 9 08-31-2011 08:00 AM
03:39 AM
