header leak - Mustang Evolution
Old 01-21-2012, 11:44 PM   #1
header leak
so i have no name headers on stock heads and im not having any luck with gaskets.. i got the header flanges milled and they still end up ticking eventually. maybe copper gaskets? mill the heads? thanks
vigilnash_89lx is offline   Reply With Quote
Old 01-21-2012, 11:53 PM   #2
WhiteCobra94's Avatar
Where did you get your headers from ?
Old 01-21-2012, 11:55 PM   #3
idk they came with the car when i got it a year ago
Old 01-21-2012, 11:58 PM   #4
Roush7492's Avatar
The black market
Roush7492 is offline   Reply With Quote
Old 01-22-2012, 12:03 AM   #5
What year mustang?
---------- Post added at 01:03 AM ---------- Previous post was at 01:00 AM ----------
What year mustang?
If you have 94-95 check the egr tube that connects to your passenger side header!
Or the headers are just cheap metal and are not sitting flushed with the heads!!
Old 01-22-2012, 12:03 AM   #6
its an 89
Old 01-22-2012, 12:39 AM   #7
check to make sure the header bolts just didnt back out a little bit.sometimes from the heat they loosen up without hurting the gasket.
Old 01-22-2012, 12:44 AM   #8
Re: header leak
Try coating both sides of the header gasket with Permatex Ultra Copper silicone sealer.
Wipe on a smooth, thin coat with your fingers.
Let it dry completely.
Wipe a thin layer of grease on the heads and header flanges.
Put some anti-seize on the head bolts, install them and torque them to spec.
After a few heating and cooling cycles, check the header bolt torque again.
If they have loosened, re-torque the bolts and check them again after a few more heating and cooling cycles. They will eventually seat in and stay torqued.
Old 01-22-2012, 12:50 PM   #9
thanks. if all fails is it a better idea to remove heads n have rebuilt and milled... or new headers??
Old 01-22-2012, 01:09 PM   #10
Re: header leak
New headers would be the cheaper and easier fix, but even that may not be necessary.
You can run a large flat file along the header flanges and exhaust ports on the heads to see if they are flat. If not work them down until they are.
A set of locking header bolts would ensure that the headers stay fastened to the heads properly.
Old 01-22-2012, 07:07 PM   #11
mystang50's Avatar
At auto zone they have some soft alum header gaskets that are thick... I had a leak and put copper ones on and it still leaked...these work great only $20
Coolant leak Napoleon 1979-1995 Mustang GT 12 01-15-2012 02:47 PM
Antifreeze cross-line leak fish 1996-2004 Mustang GT 10 12-09-2011 07:52 PM
99-04 V6 HEADER LEAK? CHILE10_STANG Pre-2005 V6 Mustang 18 11-11-2011 03:25 AM
Detecting Exhaust Leak? crkmonzo 1979-1995 Mustang GT 6 09-22-2011 11:38 PM
88 fox oil leak 04TRV6 1979-1995 Mustang GT 4 07-05-2011 02:17 PM
04:05 PM
