351 heads - Mustang Evolution
Old 01-23-2012, 04:15 PM   #1
mystang50's Avatar
351 heads
My older brother has a older Ford pick up f 150 that has a 5.0 in it...is that tha same 5.0 as mine but carb? He informed me that it has 351 heads on it...if same 5.0 will those heads work on mine? If so are they stud mounted?? Or what's diff??but its been sitting for a while...so I was Jus curious
Old 01-23-2012, 05:10 PM   #2
aegischief's Avatar
It's not the same 5.0 as you got. It's a a non-HO motor. The heads are most likely pedestal mount.
aegischief is offline   Reply With Quote
Old 01-23-2012, 05:28 PM   #3
mystang50's Avatar
So it they wont work on mine?
Old 01-23-2012, 05:43 PM   #4
the stock 351 heads will have little to gain.they are not worth switching.
Old 01-23-2012, 05:48 PM   #5
mystang50's Avatar
Thanx that's what I was wondering...though mabye I had a free set of heads...thanx guys
Old 01-23-2012, 05:58 PM   #6
deadsp0t's Avatar
Can they be ported to flow well?
That's unimpressive
Old 01-23-2012, 06:19 PM   #7
aegischief's Avatar
Kinda. If you start with a set of good heads, like a set from 1968-1971.
Old 01-23-2012, 06:19 PM   #8
probably.
i could be wrong and im sure someone will correct me.i think they drop the compression ratio a bit because of the larger combustion chamber.which decreases hp.i do know they are not a great swap but i think that is the reason.
some guys actually use to throw 289 heads on 302s just for the compression bump.
Old 01-23-2012, 06:23 PM   #9
aegischief's Avatar
probably.
Totally true about dropping compression. Figure about a drop in one, from around 9.0 with 302 HO heads to around 8.0 with 351 heads. What some folks do is shave the deck surface a little to regain some compression.
With the ease and relatively low cost of aluminum heads, makes no sense to do this anymore.
Good Information Thread. ESG642T Pre-2005 V6 Mustang 10 01-13-2012 08:00 AM
New to this...gt40p heads vs 351 Windsor.. Ponyboy66 1979-1995 Mustang GT 8 12-30-2011 10:24 PM
351 heads Tyoung68 Classic Mustangs 2 12-25-2011 05:33 PM
351 heads Cm644rodrigues 1979-1995 Mustang GT 3 11-11-2011 04:03 PM
E7 heads or Gt40 heads? Qwik Four Six 1979-1995 Mustang GT 18 10-29-2011 09:59 PM
10:21 AM
