Help!!! - Mustang Evolution
Old 01-23-2012, 07:32 PM   #1
TrickFlow94's Avatar
Help!!!
I have a 94 5.0, and I wanted to do the A9L computer swap. I've read that it can give you big gains and takes tunes better.
I needa know if anybody makes an adapter for the A9L in an sn95. Any help will be appreciated
TrickFlow94 is offline   Reply With Quote
Old 01-23-2012, 07:57 PM   #2
Re: Help!!!
I don't think it uses an adapter, I think you have to change out part of the wiring harness.
Old 01-23-2012, 08:02 PM   #3
Sounds like a lot of work.
Would it be worth the swap?
Old 01-23-2012, 08:09 PM   #4
Re: Help!!!
Do you have a 5 speed or an automatic?
Old 01-23-2012, 08:10 PM   #5
5 speed
Old 01-23-2012, 08:39 PM   #6
Re: Help!!!
5 speed
Then yes, I think it would be worth it.
It's harder to do with an automatic, because the ECU also controls the transmission. If you change to the older style ECU in an auto you also have to install a Baumannator or other transmission controller.
Old 01-23-2012, 08:45 PM   #7
Ah I see.
What pins would I have to change on the connector?
Old 01-23-2012, 09:02 PM   #8
Re: Help!!!
Ah I see.
Well, I just completed some research on doing the TM40 to A9L swap.
Apparently it is no longer "the thing to do" and the company making the harness has gone out of business.
Couple that with swap parts and tuning prices in the $1000+ range and it quickly becomes to expensive and is to difficult for most people.
Another option is to use the AFM PMS to tune the ECU that you have.
With the PMS' capabilities you should be able to tune for almost any modification you'd wish to make. It runs around $969, but it is all "plug & play" with no wiring needed and no laptop necessary to tune.
Old 01-23-2012, 09:19 PM   #9
Thanks Trojan.
You tha man!
Old 01-23-2012, 09:30 PM   #10
Re: Help!!!
Thanks Trojan.
You tha man!
You're Welcome!
Good luck with your project.
11:00 AM
