Timing Chains - Mustang Evolution
Old 01-24-2012, 12:30 AM   #1
OG86GT's Avatar
Timing Chains
Got my eyes set on 2 timing chains which would u guys prefer? Ford racing or comp cam. Both are heavy duty double rollers except ford racing is 20 bucks more
OG86GT is offline   Reply With Quote
Old 01-24-2012, 12:39 AM   #2
93slowstang's Avatar
Unless the brand name is important go with the comp cams set.
Old 01-24-2012, 07:36 AM   #3
WhiteCobra94's Avatar
What CAM are you using? If you have a aftermarket I'd go with the timing chain recommended for that CAM!
Old 01-24-2012, 07:25 PM   #4
OG86GT's Avatar
Stock cam
Old 01-24-2012, 07:32 PM   #5
Re: Timing Chains
The cam shouldn't matter. You get new gears with the timing chain set.
Old 01-24-2012, 08:15 PM   #6
Well I have the trick flow stage 1 Cam and I was told to go with the matching trick flow timing chain ! (that's what the summit racing tech told me)
Old 01-24-2012, 08:38 PM   #7
As long as its a double roller it doesn't really matter what brand you buy. The one that comes in the trickflow kit is a summit brand not their own anyway.
---------- Post added at 09:38 PM ---------- Previous post was at 09:38 PM ----------
And that's even buying the kit from LRS.
Old 01-24-2012, 08:40 PM   #8
I was gonna use edelbrocks double roller for $45 but trick flows was $75
Old 01-24-2012, 08:42 PM   #9
I bought a cloyes set. Bought one of the more expensive ones they had though.
Old 01-24-2012, 08:42 PM   #10
OG86GT's Avatar
I'm gonna go with ford racing
Old 01-24-2012, 09:04 PM   #11
Not a bad choice.
Old 01-24-2012, 09:52 PM   #12
Re: Timing Chains
That was just a ploy to get you to buy that timing chain.
They probably had a bunch of them and needed to move them out.
When I need one, I usually go for the Cloyes True Roller.
It is one of the better timing chain sets out there.
My preference would be to use a belt drive to help reduce the harmonics, but they are just to expensive.
2.3L Timing belt install deadsp0t 2.3 Mustang 13 12-05-2011 01:13 PM
Timing Chefnick 1979-1995 Mustang GT 2 11-20-2011 07:55 PM
Need help with timing cover bolts WhiteCobra94 1979-1995 Mustang GT 33 08-11-2011 02:23 PM
advancing timing 5.slow 1979-1995 Mustang GT 6 08-10-2011 10:40 AM
timing gear drive peoblem? C4king 1979-1995 Mustang GT 8 08-09-2011 08:54 PM
09:43 PM
