Steeda X2 ball joints - Mustang Evolution
Old 01-24-2012, 04:45 PM   #1
jhagan1980's Avatar
Whats everyone's opinions on these for a lowered car? I went to go get an alignment today and my ball joints are shot. The technician showed me my ball joints and they actually came out of the a arm when lifted up. Could this be due to cheap ball joints(wrong size) or could previous owner have burred out the a arm to make fit easier? I'd like to get the X2's but not if I'm gonna need new a arms. Where would be a good cheap place to get aftermarket a arms if I need to replace them?
jhagan1980 is offline   Reply With Quote
Old 01-24-2012, 07:14 PM   #2
Re: Steeda X2 ball joints
I checked them out on American Muscle and what they had to say about them was pretty impressive. Link: Steeda X2 Ball Joints
If the old joints just came out of the arm, then likely the arms are wallowed out or had been reamed out like you suggested.
A salvage yard like MPS Auto Salvage may be the least expensive place to get replacements, as I bet they are really expensive from Ford.
Maximum Motorsports also has them in OE and aftermarket style.
They both run around $350 for urethane bushings, but the aftermarket also require a coilover conversion.
Old 01-24-2012, 07:19 PM   #3
jhagan1980's Avatar
I'm thinking about getting a expensive one from autozone and trying the fitment before I buy the x2. This way I can tell if it's the arms or not
Old 01-24-2012, 07:28 PM   #4
If you have a set of calipers, just measure the inside diameter of the mounting hole in the a-arm and then go to the parts store and measure the outside of a new ball joint. There should be a few thousandths difference for the interference fit.
Old 01-24-2012, 08:34 PM   #5
jwhayne0001's Avatar
If you don't I have a digital caliper at work you can borrow
jwhayne0001 is offline   Reply With Quote
Old 01-24-2012, 09:01 PM   #6
jhagan1980's Avatar
I dont
Old 01-24-2012, 09:04 PM   #7
You want to use mine?
Old 01-25-2012, 05:06 AM   #8
jhagan1980's Avatar
Thats fine. I'll have to take it apart first
Old 01-28-2012, 08:25 AM   #9
jhagan1980's Avatar
I've read these come with spacers to keep from lowering the front another 1/2in. If I use the spacers will it still help with the geometry? Item description is below
Old 01-28-2012, 09:23 AM   #10
deadsp0t's Avatar
http://www.steeda.com/forums/index.php?topic=2716.0
This should help
That's unimpressive
Old 02-01-2012, 04:15 PM   #11
jhagan1980's Avatar
Ordered Monday delivered today. Love the fast free shipping from AM. The spacers are just aluminum donuts that slide in on top of your spring so looks like I'll be borrowing a spring compressor from a parts store.
Old 02-02-2012, 08:00 PM   #12
jhagan1980's Avatar
These are what the spacers are for the x2's. They mount on top of the springs. Would I put them under the isolator or above?
Old 02-03-2012, 05:33 AM   #13
Attachment 39889
I would say above, so your spring doesn't pound them through the isolater.
Old 02-03-2012, 06:00 AM   #14
jhagan1980's Avatar
Above the isolator or above the spring and below the isolator?
Old 02-03-2012, 06:17 AM   #15
I would put them above the isolator.
That way the spring contacts the isolator and the isolator is seated against the spacer, which is seated against the metal of the car.
If you put the spacers between the spring and the isolator. I bet the spring would eventually pound the spacers through the isolator.
Old 02-04-2012, 03:42 PM   #16
jhagan1980's Avatar
Well I had to tack weld my ball joints in due to the idiot owner before me grinding out the arms. Next time i need ball joints I'll just get some aftermarket a arms.
Old 02-04-2012, 04:25 PM   #17
That sux!
I wonder if you couldn't use some bolt in joints and just drill some holes and bolt them in.
That may be an option to look into if you don't want to spend the cash for aftermarket arms.
Old 02-04-2012, 04:28 PM   #18
jhagan1980's Avatar
I believe I should be able to grind the joint out buy grinding on just the ball joint and saving the arm. Will just have to see when the time comes I just don't want to weaken the arm with alot of heat.
Old 02-04-2012, 05:42 PM   #19
Just weld in 1/2" or 1" bead increments and you won't hurt the arms.
Old 02-04-2012, 06:04 PM   #20
jhagan1980's Avatar
That's what I did. I'm just saying if I get them out next time and then weld in more again. Heating them over and over again.
Old 02-04-2012, 06:46 PM   #21
I see.
Old 02-05-2012, 03:58 PM   #22
jhagan1980's Avatar
Ended up putting spacers into the isolator seeing how it was a perfect fit and looked like it was the best option.
Bumpsteer and ball joints installed. Now I just need an alignment and I'll be good to go.
Old 02-05-2012, 04:31 PM   #23
Here's what I found on the spacers on instructions at AM.
Originally Posted by AM
22. Next you need to drop out the jack that was holding the A-arm up and grab your coil spring. You also need to
make a decision about the spring spacers if you have not already. The installation instruction Steeda provides are useful,
however, in explaining the purpose of the included spring spacers. I recommend following these guidelines so that your
mustang’s handling will be improved as much as possible. This is what they say:
23. So, depending on your application, begin reinstalling the front suspension and steering components by putting the
coil spring back in the A-arm with or without the Steeda spring spacers between the top of the spring and the top spring perch.
Old 02-05-2012, 04:35 PM   #24
jhagan1980's Avatar
It doesn't mention the isolator. The way I see it, it's as wide as the spring itself so it would be no different then the spring pounding on the isolator.
Steeda x2 Ball Joints 01mineralgreyv8 1996-2004 Mustang GT 11 01-14-2012 10:49 PM
Steeda Cluctch Quadrant and cable. Used 83-95 Otlaw80 Mustang Parts for Sale and Wanted 0 12-17-2011 07:24 PM
Like new Steeda Tri Ax shifter for sale modular2valve Mustang Parts for Sale and Wanted 1 12-02-2011 12:27 PM
Steeda Spyder Wheels Installed! redstang10 2011-2014 Mustang GT 15 10-20-2011 12:10 PM
Steeda ultralites S197STANG 2005-2010 Mustang GT 3 10-12-2011 10:01 PM
03:39 AM
