red top optima! dead!!!!! - Mustang Evolution
Old 01-25-2012, 05:51 AM   #1
91BlueMule's Avatar
Man I get off work and what do u know I have a dead battery!!! I've had this red top for 6 months. My previous yellow top lasted 6 years before it went dead! Can somebody give me some answers or clues to what's up with this battery!
91BlueMule is offline   Reply With Quote
Old 01-25-2012, 06:12 AM   #2
It's not me, it's you.
primer2tone's Avatar
It might just be a defective battery. It coulda had a weak cell. You should have a one or two year free replacement on that battery.
Old 01-25-2012, 06:15 AM   #3
91BlueMule's Avatar
I think I got a 3 year warranty. But the Guy at autozone wants to try and charge it before he will replace it! I think that B.S.
Old 01-25-2012, 06:29 AM   #4
Yeah, that is bull. They have to do it for warranty purposes. What sucks is if it's weak, after they charge it, it will pass the load test and they'll say it's a good battery and the problem is your car. What I did when I had a similar issue is, I deep cycled the battery overnight. Then returned it. They charged it and then tested it. It failed and they replaced the battery. this new red top I got has since out lived my last car.
Old 01-25-2012, 06:35 AM   #5
91BlueMule's Avatar
This mite sound stupid but how do u deep cycle a battery? Thanks!
Old 01-25-2012, 07:14 PM   #6
Re: red top optima! dead!!!!!
From what he said I am guessing that he totally discharged the battery.
I.E. Leave the headlights on all night.
Are you sure you don't have a short circuit somewhere or accidently left on a light?
I had a small light under the hood of one of my vehicles that stuck on and kept draining my battery. I finally found it one night because it was shining on the ground under the car.
Old 01-25-2012, 07:57 PM   #7
91BlueMule's Avatar
Thanks I'll check. I never had any issues with my yellow top. Do u think I need to switch back from the red to yellow?
Old 01-25-2012, 08:48 PM   #8
The Yellow is a deep cycle battery and is more expensive.
Unless you are running a lot of electrical accessories, the Red should serve you just fine.
Old 01-25-2012, 08:56 PM   #9
Blogger
99ford's Avatar
I'd make replace it. Doesn't Johnson Controls make it? If they do there shouldn't be any issues. AutoZone buys millions of battery's a year.
I had an issue with my battery at about 45 months. Took it back to my Ford Dealer and they replaced free of charge. I Wasn't expecting that at all. I was expecting to pay the pro-rated deal.
Old 01-26-2012, 06:28 AM   #10
91BlueMule's Avatar
Just an update.... autozone wants to keep my battery for about 4 hours and try to slow charge it. Not sure of the outcome yet. Gonna go back after I get a few hours of sleep! You gotta love 3rd shift!
Old 01-26-2012, 06:59 AM   #11
Eturner's Avatar
Sounds like that AutoZone is trying to give you the runaround!... And if that's the case then that's a bit shocking!.. The ones around here are quick to replace items that are under warranty!... Hopefully that's what they end up doing for you!.. Otherwise I'd take money elsewhere!..
Old 01-26-2012, 07:17 AM   #12
WhiteCobra94's Avatar
I am on my 6th battery in the past 2 years from autozone, they're JUNK!!!
Old 01-26-2012, 07:24 AM   #13
Eturner's Avatar
Blaming the store for a manufacturers defect don't make much sense!.. I'm on my second battery in 12 years from Autozone!.. No problems!..
Old 01-26-2012, 09:29 AM   #14
Well for a $64 battery I guess I got what I paid for!!!!
Old 01-26-2012, 10:08 AM   #15
Eturner's Avatar
That's why I always ask what all brands they have for what ever parts!...
Old 01-26-2012, 11:42 AM   #16
Redsteel's Avatar
i dont like buying electrical stuff from autozone. ive had many problems with the items ive purchased and ive had a couple of employees there tell me i should just go to advance auto
Redsteel is offline   Reply With Quote
Old 01-26-2012, 12:12 PM   #17
That's understandable.
The best way to charge any battery is very slowly so they don't boil and gas out which will cause the formation of scale and buildup on the plates slowly rendering them useless.
Old 01-26-2012, 01:51 PM   #18
bigcolt45's Avatar
I can tell you from experience at my shop we deal with interstate and nobody makes a battery like they did 5 or more years ago. IMO
bigcolt45 is offline   Reply With Quote
Old 01-26-2012, 09:38 PM   #19
91BlueMule's Avatar
well the autozone charged the battery it read 13.5v. He said its a good battery and to try it out.
Old 01-26-2012, 10:06 PM   #20
It should be fine. Any voltage from 12.5 & up is considered good.
You must have a small short circuit draining your battery?
Old 01-26-2012, 10:48 PM   #21
91BlueMule's Avatar
I checked the battery cables and they were ok. I believe its got somethin to do with either the radio or the flip down map light. I just replaced the light about 2 months ago.
Old 01-26-2012, 10:53 PM   #22
Try pulling the bulb, disconnecting or removing fuses on any problem accessories you might suspect. If the battery stays up with them removed, then you have located your problem.
Top leaking Ajhboy94 1996-2004 Mustang GT 1 01-12-2012 06:04 PM
Trick flow top end kit 1996 4.6 Rebbew 1996-2004 Mustang GT 5 01-08-2012 09:31 AM
help, 91 vert with 80's top frame? what top to buy? jmuddyman 1979-1995 Mustang GT 3 10-17-2011 02:22 PM
Red or Black? cruisin99coupe Mustang Paint, Appearance & Detailing 18 09-30-2011 01:17 AM
Convertible Top Pump with Metal Shavings Xexyz General Mustang Discussion 1 08-12-2011 06:26 AM
07:49 AM
