i need help - Mustang Evolution
Old 01-28-2012, 09:06 AM   #1
i need help
Hey guys I've still been trying to get my car running at it's best. But it ain't lookin good. But. I was wandering something. All my smog stuff isn't hooked up anymore. And I have the line removed from the egr valve and capped off. But I don't get no codes for nothning. I've only got one code the whole time I've had the car. And it was for the fan. But the car is missing alittle when I get up in the revs. But it almost sounds like it is barley popping or backfiring out of the exhaust instead of missing. But it is just barly making a sound when it does it. I've never heard a motor do this b4. But I was just wandering shouldn't I be getting more codes. Like lean or rich codes. And shouldn't the egr valve set off a code. When I do research on the Internet about mustangs. People usualyy say they have like 5 or 6 codes when there car isn't running good. Any help would be greatly appreciated.!!
Robbie94gt is offline   Reply With Quote
Old 01-28-2012, 09:50 AM   #2
Did u check ur timing?
Old 01-28-2012, 09:57 AM   #3
Not yet but I set it about 3 months ago at 10. I tried avancing at that time to just 11 amd it started pingin so I put it back to 10. With a running light. But also after I druve my car for say 30. Mins and then shut it off amd try to start it right back up it has to crank a few times just like I was starting it cold. I've always heard that a motor thst is timed right should start with back up when warm. Is that true. Also I put a new coil on it. But what about the codes. Shouldn't that smog stuff be turnin on a code. I've had the car for bout 8 months and it's runnig stronger now then it ever has but it's missing now. It used to never miss. I've never heard one pop out the exhaust like that just barly. I've heard themback fire loud out the exhaust but mine is not doing that. But thanks for your help. It means a lot
---------- Post added at 01:57 PM ---------- Previous post was at 01:56 PM ----------
* timming light
Old 01-28-2012, 10:01 AM   #4
Meansaleen's Avatar
When you tried advancing timing what type of fuel did you have in your tank? And what type of fuel do you currently use?
Meansaleen is offline   Reply With Quote
Old 01-28-2012, 10:01 AM   #5
U may need to check your fuel pressure.u may be running lean which could be why u couldn't get more the 11*.
Old 01-28-2012, 10:19 AM   #6
I use 89 all the time. Amd I checked the pressure 2 weeks ago. It was 32 at idle. 40 with the vacuum off the regualtor amd plugged. The only thing concerned me was that when I reved it up to 2500 rpm the pressure dropped about 4 psi. Shouldn't it rose instead of dropping.
---------- Post added at 02:19 PM ---------- Previous post was at 02:18 PM ----------
And I was using 87 at the time amd haven't tried to advance it since I've been using alittle higher octane
Old 01-28-2012, 10:23 AM   #7
Meansaleen's Avatar
When advancing timing u have to use premium 93 or better. My timing before supercharger was 14 degrees. And I never had pinging with premium fuel. Try using premium fuel. I suspect it might be crappy gas in your tank. Have you used fuel stabilizer?
Old 01-28-2012, 10:41 AM   #8
No I haven't but it runs good don't backfire or miss or nothin untill I push the pedal over halfway then it starts cutting out but it still picks up speed. My vacuum is 17 amd steady. But what would cause the small backfire out the exhaust if the timming is at 10. Could clogged injectors do this. ? Apparentaly the car set for a while b4 I got it cuz there was like 2 or 3 dirt dopper nest between the upper and lower intake. Signs of it sitting a while. But I know no history on the car. But I have drove the piss out of this car. It's it just strange. When I first got it. It ran good but didn't fell like it ran at it's full potental. It never missed or backfired Now I've done a few things like full exhaust amd gears amd it's stronger than it ever has been but missing/backfiring. I'm just runnig out of options. I have a set of gt40 heads amd intake waiting to go but I want to get this straighted out b4 I put those on there and have more problems with ya
Old 01-28-2012, 09:37 PM   #9
Re: i need help
The 40 psi at idle with the vacuum hose off is good, but it should not drop all the way down to 4 psi. Some drop is normal, but that is too far. I would suspect the pressure regulator is not working properly.
The injectors could very well be dirty and in need of cleaning. The nozzle is very small and it does not take much to clog them up. Old, varnished fuel can do that every time.
The popping out the exhaust can also be caused by a burned or leaking valve. Usually it is the exhaust valve, which can get a piece of carbon wedged between the valve and seat and not seal up properly.
03:26 PM
