what yall think? - Mustang Evolution
Old 01-28-2012, 08:47 PM   #1
FLAT BLACK GT's Avatar
what yall think?
List of mods ordered. Bbk 70mm tb, MAC ud pullies, bbk cold air kit, sct 4bank eliminator chip, bbk equal length shorties, billet smog pump delete, and a Ford racing aluminum drive shaft. Should be a good improvement right? Cars already geared 4.10 and has been freshly tuned up with msd cap wires plugs ig coil rotary button all fluids changed everything.
FLAT BLACK GT is offline   Reply With Quote
Old 01-28-2012, 09:24 PM   #2
WhiteCobra94's Avatar
Tuned right 35-40hp
Old 01-28-2012, 09:28 PM   #3
Crank or wheel HP?
Old 01-28-2012, 09:30 PM   #4
Stang.racr's Avatar
Crank
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 01-28-2012, 09:32 PM   #5
mystang50's Avatar
Nice! hate to see the total price lol
Old 01-28-2012, 09:53 PM   #6
LAS97GT's Avatar
Re: what yall think?
Man, that's a lot of goodies. Like the man said, hot girlfriend that wont put out. So, what's the endstate? RWHP? From what I heard, bolt-ons increase torque on RW, but not engine HP. I believe, man.
Las 97GT
Old 01-28-2012, 09:56 PM   #7
Las 97GT
That's not entirely true.
Some of his mods will free up some HP and others will add a bit.
You can't really increase one without affecting the other in some way, be it adding or subtracting from the total produced.
Old 01-28-2012, 10:06 PM   #8
Originally Posted by FLAT BLACK GT
Crank or wheel HP?
Now if you had other supporting mods like heads and intake, cam, you'll get more out of the mods you have listed. Everything works together !!!
Old 01-29-2012, 10:54 AM   #9
That's coming ha this was 1500 bucks with the couple cosmetic things so I wasn't able to do much more. Idk maybe I can have enough saved for the trick flow top end kit that I want by mid summer. I also wanna upgrade the injectors soon..
---------- Post added at 12:54 PM ---------- Previous post was at 12:17 PM ----------
What kind power estimate can I look at after the top end kit and ugrading the fuel system. Also what size injectors fuel pump etc should I be ugrading to?
Old 01-29-2012, 11:34 AM   #10
If you do the Trick Flow HCI kit and end up with around 350 HP you will need 30lb injectors to supply the correct amount of fuel.
Here is an Injector Size Calculator that you can use yourself to size injectors for your combination.
Old 01-29-2012, 06:46 PM   #11
Haha thanks that's pretty cool.
what yall think mystang50 1979-1995 Mustang GT 11 12-30-2011 03:14 PM
What do yall think. silver98mustang 1996-2004 Mustang GT 1 12-24-2011 04:55 AM
sup yall, new from tx 236mustang New Member Introductions & Greetings 20 12-08-2011 07:20 AM
New here and wanted to show yall my mustang Nickp45 1979-1995 Mustang GT 15 10-07-2011 06:44 PM
What do yall think? Roush Jamesgt08 1996-2004 Mustang GT 53 08-12-2011 07:16 PM
01:51 PM
