91 5.0 Mostly Stock - Page 3 - Mustang Evolution
Old 02-07-2012, 08:28 PM   #71
Re: 91 5.0 Mostly Stock
Originally Posted by JayKranz View Post
Cool, thanks for the help.
---------- Post added at 08:09 PM ---------- Previous post was at 08:06 PM ----------
With the silicone sealer you just mean the stuff from Napa or wherever for the upper and lower intake gaskets right?
I use some silicone called Super 7 High Temp & Oil Resistant. Darned if I can remember the brand name though.
It comes in a caulking gun tube, but may be available in smaller quantities.
Ah cool thanks. I really appreciate all the help and advice everyone is giving me. I am a noob(4th mustang) and this is going to be my first modified car so much of this stuff is foreign to me. Anyway I really appreciate all the advice so far.
---------- Post added at 08:22 PM ---------- Previous post was at 08:12 PM ----------
Any recommendation for a boost gauge for this on3 kit?
If you can afford it buy a good Autometer or other name brand. If not then one of the cheaper gauges should work just fine.
Old 02-07-2012, 08:30 PM   #72
What is the best way to mount one of the gauges?
JayKranz is offline   Reply With Quote
Old 02-07-2012, 09:04 PM   #73
I bought a pillar pod to put mine in.
Old 02-07-2012, 09:08 PM   #74
Does it just run off a vacuum to something?
---------- Post added at 09:08 PM ---------- Previous post was at 09:08 PM ----------
I am looking at the $60 auto meter ultra lite gauge but unsure where it hooks up to the turbo?
Old 02-07-2012, 09:24 PM   #75
Hooks into the intake and reads the boost/vacuum there.
Old 02-08-2012, 07:50 AM   #76
Do I use the Rtv Black with my regular gaskets or in place of them?
Old 02-08-2012, 08:48 AM   #77
Looking at center force clutches any input on which one I need for my stock 91 5.0 would be appreciated.
Old 02-08-2012, 09:57 AM   #78
Depends upon which gaskets you are talking about.
Google search installation of whatever you are working on and look for a magazine article pertaining to that part. They will usually tell you what you need to know.
Center Force Dual Friction.
Up to 90% increase in holding power and reduced pedal effort.
Old 02-08-2012, 06:31 PM   #79
Ordered the center force dual friction clutch Pretty excited about all of this. Can't wait to build my car next week and then drive the crap out of it.
Old 02-08-2012, 06:38 PM   #80
I think you will like it. I've had mine for over 10 years now and it's still working just fine.
Old 02-08-2012, 09:36 PM   #81
On3 kit will be here Monday as well as many other things. Took next week off of work, hopefully I can get all of this finished.
Old 02-08-2012, 09:54 PM   #82
awsome.dont forget to make sure u get it tuned and its right before u go romping on it.
Old 02-08-2012, 09:58 PM   #83
Will do
---------- Post added at 09:58 PM ---------- Previous post was at 09:56 PM ----------
I bought everything you guys told me to do this should be okay.
Old 02-11-2012, 07:22 AM   #84
Originally Posted by Lh3211986 View Post
I went to my local mustang speed shop and told them I was stock head and a turbo kit. They gave me the gasket I need it. For the pair it was $190.
Did you wrap your downpipe, crossover pipe and spark plug wires?
Old 02-11-2012, 07:02 PM   #85
Anyone have an estimate of how long installation might take for the ON3 turbo kit? Mine is on its way and I will probably get it Tuesday or Wednesday and I took the week off. Just hoping I can get it done.
Old 02-11-2012, 07:27 PM   #86
I'd estimate 2, maybe 3 days if you don't have to do much fabrication.
Then a day or two tuning and working the bugs out.
Do NOT be tempted to romp on it a bit until it has been tuned properly.
Lots of 5.0 pushrod engines have died an early death from just that scenario.
Old 02-11-2012, 07:28 PM   #87
Got it, thanks buddy. I will tune it first. When you say tune you mean timing, fuel pressure etc...
Old 02-11-2012, 07:39 PM   #88
Yes, those and you will need something like the MSD Timing ****** to sense the boost and pull timing out to keep it from detonating as it build boost pressure. Just a little bit of detonation under boost can destroy a piston.
Ensure you have plenty of fuel to it too and go easy on it until you have a safe tune.
Are you going to chip it, have it dyno tuned or are you looking at the AFM PMS?
Old 02-11-2012, 07:52 PM   #89
I have a chip coming with the kit. Since my car is stock with the exception of the turbo the guys at ON3 said that my car should be pretty good with the tune they are sending. They also said better safe than sorry and that a dyno tune should happen in the near future just in case.
---------- Post added at 07:51 PM ---------- Previous post was at 07:44 PM ----------
Do I need the timing ****** with the chip? I was under the impression that I didn't need it?
---------- Post added at 07:52 PM ---------- Previous post was at 07:51 PM ----------
Fal pro make a turbo head gasket. That's what I'm using. And ARP studs and bolts it comes together.
Did u use a timing ****** or chip or what with ur on3 kit?
Old 02-11-2012, 08:23 PM   #90
If you have a chip from On 3 it should have the timing ****** function built in I would hope.
Old 02-11-2012, 08:28 PM   #91
Okay cool, I will definitely double check with them before I get too crazy. I appreciate all of the advice here, thanks again!
Old 02-11-2012, 08:30 PM   #92
You're Welcome and Good Luck!
Old 02-11-2012, 10:20 PM   #93
88gtCc's Avatar
Be sure to keep us posted on how the install goes and your hp/tq numbers when you get tuned
88gtCc is offline   Reply With Quote
Old 02-12-2012, 06:32 AM   #94
I definitely will.
Old 02-12-2012, 06:17 PM   #95
Can not get the metal fuel couplers off by the fuel rails help!!!
Old 02-12-2012, 06:22 PM   #96
deadsp0t's Avatar
I believe there is a specific tool for that
That's unimpressive
Old 02-12-2012, 06:34 PM   #97
Fuel Line Tools
Use those to disconnect your fuel lines.
You insert the tool to push the locking spring out of the way, then just pull the lines apart.
Do not attempt to force the lines apart or you could damage the spring and coupler.
Old 02-12-2012, 06:38 PM   #98
deadsp0t's Avatar
Originally Posted by Trojan Horse
Fuel Line Tools
I get it right sometime!
That's unimpressive
Old 02-12-2012, 06:42 PM   #99
Yep
The way I figure it, we always have a 50/50 chance of being correct.
Old 02-12-2012, 06:43 PM   #100
deadsp0t's Avatar
Yep
I might be 50/50, you like 95/5
That's unimpressive
Old 02-12-2012, 06:47 PM   #101
okay, thanks. I'll hit Napa in the morning.
Old 02-12-2012, 07:11 PM   #102
Note: If they have the metal versions, they are more durable and I think easier to use.
Old 02-12-2012, 07:12 PM   #103
okay I'll give it a shot
Old 02-13-2012, 08:42 PM   #104
Should I coat my Trick Flow MLS gaskets with copper spray?
Old 02-13-2012, 10:10 PM   #105
If they are rubber (of some type) coated like the Cometic gaskets, then no you should not have too.
My official 5.0 engine swap thread PureVenom 1979-1995 Mustang GT 35 10-06-2013 01:12 PM
1987 Mustang GT 5.0: Huge Help Needed Johnson 1979-1995 Mustang GT 24 01-18-2012 09:19 PM
Porting stock 5.0 heads SmokedLX 1979-1995 Mustang GT 12 01-01-2012 01:57 AM
Installing a supercharged 3.8 from a thunderbird SC into my 99 mustang skip318 Pre-2005 V6 Mustang 12 10-01-2011 10:03 PM
Fastest stock 5.0 wnt2gofst 2011-2014 Mustang GT 2 09-01-2011 06:23 PM
12:00 PM
