Spark Plugs - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 01-30-2012, 07:17 AM   #1
DaBomber is unknown around these parts
Spark Plugs
Was going to replace the spark plugs of my 91 5.0 LX and I encountered a problem, I couldn't decide what plugs to get. There are a lot of them from NGK Iridium IX to the G-Power, the V-Power, and the Ford Motorcraft OEM. I was wondering if there were any y'all would particularly recommend, since I will be sticking with them for a while. Thank you.
DaBomber is offline
Old 01-30-2012, 08:10 AM   #2
Eturner's Avatar
Eturner is unknown around these parts
Pretty much plugs are plugs!.. There is no real gain from them, unless you have a full aftermarket setup from like MSD!..
Eturner is offline
Old 01-30-2012, 08:31 AM   #3
I'm pretty sure my car is stock with the exception of the seats
DaBomber is offline
Old 01-30-2012, 08:36 AM   #4
deadsp0t's Avatar
deadsp0t is unknown around these parts
Wrong, sorry.
Depending on your temp range I suggest you use Auto Lite's, plain copper cores.. I use only AutoLite #25's some prefer #24's
That's unimpressive
deadsp0t is offline
Old 01-30-2012, 08:59 AM   #5
So there could be a slight advantage between plug types? What could those be?
DaBomber is offline
Old 01-30-2012, 09:08 AM   #6
deadsp0t's Avatar
Heat ranges your car operates in.. For example I believe nitrous uses a colder range.
That's unimpressive
deadsp0t is offline
Old 01-30-2012, 09:09 AM   #7
Stang.racr's Avatar
Stang.racr is unknown around these parts
This is one
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline
Old 01-30-2012, 09:33 AM   #8
Eturner's Avatar
Wrong, sorry.
I don't think he was asking about heat ranges and all!.. I think he was asking about using one brand over another!..
Eturner is offline
Old 01-30-2012, 09:35 AM   #9
deadsp0t's Avatar
Even still, they are very different.
That's unimpressive
deadsp0t is offline
Old 01-30-2012, 09:43 AM   #10
Eturner's Avatar
Sorry but I do believe you are wrong on that one!... When I switched out my plugs (Factory vs Bosch Iridium) I saw no real difference between the two!.. And you don't much more different than that!.. Lol.
Eturner is offline
Old 01-30-2012, 09:47 AM   #11
deadsp0t's Avatar
First of all, you have a different engine entirely, and second anyone in the know would have told you not to waste your cash..
That's unimpressive
deadsp0t is offline
Old 01-30-2012, 09:52 AM   #12
Eturner's Avatar
True!.. But how does that support your claims as to the difference in plugs when comparing Just brands?...
Eturner is offline
Old 01-30-2012, 09:57 AM   #13
deadsp0t's Avatar
Facts, not claims. Different engines like different plugs and react differently to different brands. Particularly the push rod 5.0's. I've had 5.0's for 16 years and have used about any plug you can name. AutoLite 25's or motorcraft plugs run best in 5.0's, being the OP has a 5.0......
That's unimpressive
deadsp0t is offline
Old 01-30-2012, 10:51 AM   #14
Terminator Owner
SpectorV is just getting started.
Re: Spark Plugs
as has been said, get the right range plug in copper and get a good brand but a plug is basically a plug.
SpectorV is offline
Old 01-30-2012, 12:25 PM   #15
kid_kash_00 is unknown around these parts
Re: Spark Plugs
dont get the hige dollar e3 plugs i tried them and my stang spit and spurter for 2 weeks change plugs with ngk and car ran fine ever since
kid_kash_00 is offline
Old 01-30-2012, 02:28 PM   #16
Senior Member
Trojan Horse is just getting started.
Re: Spark Plugs
Several years back I did a lot of research on spark plugs.I had numerous manufacturers send me examples of their latest and greatest.
I bench tested the plugs on a homemade 40,000 volt tester.
It would have been better if I could have tested them under typical cylinder pressures, but I did not have the money or means to affect that type of test.
What I found out is that, unless you need a specialized plug for forced induction or nitrous use, there are no big improvements from any of the gimmick plugs over the standard old Autolite #25 Copper Core spark plugs.
However, I did find during my research that the fine tipped Irridium spark plugs had been proven to work better for forced induction or nitrous use.
They are harder, stronger, have a higher melting point and less resistance than regular plugs. They provide a more focused ignition for better overall ignitability and improved durability.
Also Platinum plugs do last longer because of Platinum's higher melting point. They do not wear as fast as a traditional plug. They do Note: That you should not use Platinum plugs with nitrous.
Trojan Horse is offline
Old 01-30-2012, 06:44 PM   #17
Otlaw80's Avatar
Otlaw80 is unknown around these parts
Re: Spark Plugs
I will also cast my vote for standard copper autolites or motorcrafts. Good plug for a good price. The expensive "special" plugs imo are just a way to seperate a man and his money.
At the very least, anything except Champion will do
Otlaw80 is offline
Old 01-30-2012, 07:40 PM   #18
Senior Member
Re: Spark Plugs
+100
I never could get much use out of Champions other than using them in lawnmower engines.
Even then they were always fouling or quitting when I was in the middle of the yard or anywhere away from the shop.
Old 01-31-2012, 02:51 AM   #19
Senior Member
Hawk is unknown around these parts
So yall think #25s are the boom in a 5.0 like mine. ill have to grab some ive been wanting to swap mine ever since my pops put champs in and swaped out my dual prong v groove platnums. i could have killed him. But what can u do hes family right lol!
Hawk is offline
Old 01-31-2012, 04:25 AM   #20
Senior Member
Re: Spark Plugs
I would, but the choice is yours.
Closed Thread
ngk laser iridium spark plugs osonasty Pre-2005 V6 Mustang 4 01-05-2012 12:14 AM
used 98 mustang and new spark plugs Deadpool Pre-2005 V6 Mustang 4 11-02-2011 10:09 PM
120,000 mile spark plugs? Just_John Pre-2005 V6 Mustang 2 10-08-2011 09:43 AM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2009 V6 Mustang 6 09-28-2011 09:45 AM
Spark Plugs may be needed jjsg09 1996-2004 Mustang GT 2 09-12-2011 05:05 AM
01:21 AM
