A cool engine - Mustang Evolution
Old 01-31-2012, 10:17 AM   #1
89white GT's Avatar
Region: Iowa
A cool engine
When I bought my mustang my cousin said he put a 93 cobra waterpump pulley in it And a 165 degree thermostat. So my engine barely get over 140 degrees. This won't hurt anything will it? I always thought a cool engine is a good thing.
89white GT is offline   Reply With Quote
Old 01-31-2012, 10:53 AM   #2
I would put a stock or at least 180 in it.a cool air charge is good but not cool engine.
Old 01-31-2012, 11:01 AM   #3
deadsp0t's Avatar
You want it to get out of the cold loop though and 160* won't do that.. I'll be switching to a 180* as well.
That's unimpressive
Old 01-31-2012, 11:50 AM   #4
Re: A cool engine
I don't remember which thread in this forum I recently posted some info about this, but you are better off for numerous reasons to leave the stock temperature thermostat in the engine.
First and foremost is that cooler T-Stats cause increased cylinder wear.
And, the entire EEC IV system is designed to run/tune at the factory designated temperature.
The "only" time you might want to run a cooler T-Stat, is on a race only vehicle.
Here is what I found on the net. It pretty much agrees with what I read in my book.
Change (or remove) the factory thermostat
This is based on the fact that cooler air is denser, so the less you heat the air coming into the engine, the more air/fuel mixture you can pack into each cylinder. An old shade-tree mechanic fix, but it's got several strikes against it. First, you never want to remove the thermostat completely. The cooling system has been designed with the thermostat restriction in mind, and removing it will actually hurt cooling. Second, cylinder wall wear increases as operating temperatures are lowered. The stock Mustang thermostat is set for 196° Fahrenheit. Dropping to 180° will increase wear somewhat, and dropping to 160° or 140° will increase wear dramatically.
On EFI cars, cooler thermostats are rumoured to increase performance because the engine will run richer at temperatures below 180° Fahrenheit. True, the EEC-IV will richen the mixture, but staying in "warm up" mode entails more than just a richer mixture. The EEC-IV will be more conservative with the timing curves, and will never get into "closed loop" operation (where it uses the oxygen sensors to fine-tune the mixture). The result will likely be poorer drivability and _decreased_ performance. Also, catalytic converters can be damaged over time by an engine that's continually running rich.
VERDICT - Don't remove the thermostat entirely, and don't use a thermostat below 180° Fahrenheit on an EFI car.
Old 01-31-2012, 12:41 PM   #5
89white GT's Avatar
Region: Iowa
So with a stock thermostat what temp would it run at?
Old 01-31-2012, 12:42 PM   #6
deadsp0t's Avatar
Think 212*
That's unimpressive
Old 01-31-2012, 12:51 PM   #7
89white GT's Avatar
Region: Iowa
So did the cobra's have a different T stat or did they run cooler?? Why are the water pump pulleys smaller on the cobra?
Old 01-31-2012, 12:56 PM   #8
deadsp0t's Avatar
Not sure about the Cobra Tstat, but generally when pulleys are smaller means they will spin faster(helping w/ cooling?).
That's unimpressive
Old 01-31-2012, 12:58 PM   #9
89white GT's Avatar
Region: Iowa
Well ya. But you would think if it was for that simple reason they would've used them on all 5.0 motors
Old 01-31-2012, 01:13 PM   #10
Re: A cool engine
What I read said stock they use a 192 or 195 degree thermostat and the system is designed to run at 200 degrees.
Old 01-31-2012, 01:15 PM   #11
Re: A cool engine
Don't know about the different T-Stat.
The pulleys may have been UD to pick up some extra HP for the Cobra.
Old 01-31-2012, 01:16 PM   #12
deadsp0t's Avatar
The difference is the Cobras and Cobra Rs are slightly more race oriented stock v. Stock when compared to an LX or a GT, imo of course.
That's unimpressive
Old 01-31-2012, 01:18 PM   #13
deadsp0t's Avatar
Aren't there a few other upgrades to the Cobras?
That's unimpressive
Old 01-31-2012, 01:26 PM   #14
Re: A cool engine
Yes, I was just thinking that might be one of them.
I'm not 100% sure and I'm too tired to search it out right now.
Plus since none of us has one I guess it doesn't really matter.
Old 01-31-2012, 04:48 PM   #15
89white GT's Avatar
Region: Iowa
Haha! Very good point Trojan!
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
selling a 1989 4 cylinder mustang with a 5.0 engine and transmission both working 1987mustanglx50 2.3 Mustang 0 01-25-2012 01:30 PM
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 12:39 AM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
05:01 AM
