Cobra intake - Mustang Evolution
Old 02-01-2012, 08:22 AM   #1
Cobra intake
Just got me a 93 cobra intake with rails stock injectors and spacer. Question can I use my tb and maf I got a 95 anything else I should need. I'm gonna change the cam when I pull the intake I'm thinking b303 I have a 5spd any suggestions
tbonestang is offline   Reply With Quote
Old 02-01-2012, 09:35 AM   #2
04machazblue's Avatar
U will need a maf calibrate for the Injectors a 65mm tb for the intake I would consider a e cam
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 02-01-2012, 10:49 AM   #3
I thought e cams were for aod
Old 02-01-2012, 03:01 PM   #4
Re: Cobra intake
Your TB & MAF should work just fine, you may however need to purchase the elbow to ensure proper fitment of your throttle linkage and intake air piping.
Make sure the cam you choose will work ok with the ECU in the 95.
They are kind of picky as to cam size unless you have them tuned for it.
Old 02-01-2012, 05:58 PM   #5
WhiteCobra94's Avatar
One of the best cams for 94-95 mustangs is trick flow stage 1 cam!!
Old 02-01-2012, 06:08 PM   #6
mystang50's Avatar
X2 on elbow
Old 02-01-2012, 07:45 PM   #7
Any elbow or do I need a particular one
Old 02-01-2012, 08:09 PM   #8
Re: Cobra intake
You need the TB elbow for the SN95 Mustang.
Old 02-01-2012, 09:54 PM   #9
Make you you get the right size elbow (70mm) edelbrocks is $110 I know trickflow makes a 70mm & 75mm
Old 02-02-2012, 07:40 AM   #10
I'm starting to think I should sell the 93 and look for a 94 to 95
SOLD! Comp Polymers Upper Box Intake for GT40/Cobra Lower Trojan Horse Mustang Parts for Sale and Wanted 4 04-04-2012 07:08 PM
93 Cobra upper intake bolts Chefnick 1979-1995 Mustang GT 8 11-07-2011 08:38 PM
cobra intake.. mike hawk 1979-1995 Mustang GT 7 10-28-2011 10:13 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
12:25 PM
