A Couple Questions - Mustang Evolution
Old 02-01-2012, 10:11 PM   #1
jacob.a.gasparp's Avatar
Region: Nebraska
A Couple Questions
1. Are dual exhausts coming straight back from the headers and not connecting in any way, just going straight back with mufflers, stock on a 1989 Mustang GT 5.0?
2. Has anyone else every had their brake light for the E-brake come on randomly every now and again?
3. Does anyone have any hints on how to get glue off of the rear hatch where tint came off the window? Would you use like paint thinner/ stripper or some kind of goof off?
thanks guys
jacob.a.gasparp is offline   Reply With Quote
Old 02-01-2012, 11:08 PM   #2
aegischief's Avatar
thanks guys
1. No. They connect via a h-pipe after the headers.
2. Never happened to me but sounds like a malfunctioning activation switch. Would be located around the ebrake lever
3. Goo-b-gone works pretty good.
aegischief is offline   Reply With Quote
Old 02-02-2012, 10:44 AM   #3
Adogg's Avatar
Yeaa i would also say goo be gone are u trying to but the tint back on after removing the glue?
Don't hate....... appreciate
Old 02-02-2012, 11:42 AM   #4
mystang50's Avatar
thanks guys
2. mine does it and mines a 95...heard it does it to signal low break fluid but mine is full so I'm not sure why mine still does it, and idk if it means diff cuz diff years but check ur fluid
Old 02-02-2012, 12:32 PM   #5
Elfman's Avatar
+1
Elfman is offline   Reply With Quote
Old 02-02-2012, 01:20 PM   #6
Re: A Couple Questions
If you are not working around a rear window defrosting grid, you can use a razor bladed scraper to remove almost all of it pretty easily.
Old 02-02-2012, 02:14 PM   #7
Region: Nebraska
Ill check the brake fluid for sure. I never thought of that.
There is a defroster system on there. I dont really think it works to well. Ill try that goof off and hopefully that will work for me.
Tyhanks for letting me know about the exhaust. I thought that system was after market.
Old 02-02-2012, 02:24 PM   #8
Your car will run and sound better with an H or X-pipe.
Old 02-03-2012, 02:50 PM   #9
Region: Nebraska
Why is that exactly
Old 02-03-2012, 03:32 PM   #10
Why is that exactly
Cause I said so.
Through an H or X pipe the exhaust gases from each side mix and that smooths out the cylinder pulses so it improves and balances the flow.
Old 02-03-2012, 03:56 PM   #11
Region: Nebraska
Oh ok thanks
Old 02-04-2012, 03:44 AM   #12
Region: Alaska
As far as taking of tint goes I swear by rubbing alcohol. I tried everything. But if you just use it in a spray bottle it works great. But be careful that stuff has some pretty bad fumes.
91redfox is offline   Reply With Quote
Old 02-04-2012, 06:32 AM   #13
Region: Nebraska
I imagine. I would pry have the hatch completely open if I used the rubbing alcohol method. Pry will for any of the method. Thanks guys for all the awesome input.
T-5 questions captain78 1979-1995 Mustang GT 9 03-06-2012 12:42 PM
95 GT questions deadsp0t 1979-1995 Mustang GT 54 11-04-2011 03:16 PM
90-93 5.0 Questions... Roddy 1979-1995 Mustang GT 11 10-12-2011 08:40 PM
Newbie , Questions on moding a 2004 mustang demo214 Pre-2005 V6 Mustang 16 08-12-2011 05:59 PM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 11:55 PM
10:17 PM
