94gt ud pulley prob - Mustang Evolution
Old 02-02-2012, 06:59 PM   #1
Sky94GT's Avatar
94gt ud pulley prob
Recently put BBK ud pulleys on my 94gt and since then my voltage has been jumping all over the place. Anyone else experience this problem and is there a way to correct it? Thank you for any help.
Sky94GT is offline   Reply With Quote
Old 02-02-2012, 07:08 PM   #2
yes very common when using underdrive pulleys.since your alternator is underdriven it is now not charging enough.its usually best to use a high amp alternator.what i did was put a smaller pulley on my alternator to make up the pulley difference.now doing this kind of defeats the purpose of having ud pulleys(at least on the alternator)i only did this beacause i bought the off road accesory drive kit from lrs that came with ac delete,smog delete and ud pulley.i like the look of the new pulleys so i just changed the alternator pulley and belt length and used the rest of the kit.
Old 02-02-2012, 07:56 PM   #3
Sky94GT's Avatar
Thank you for the advise I guess I will just uninstall them when I get the chance. They don't seem to be worth the headache.
Old 02-03-2012, 06:46 AM   #4
Re: 94gt ud pulley prob
You should have the 3G, 130A alternator on your car and the pulleys should not have that much of an adverse effect "UNLESS" you have added other high power draw accessories or you have a charging system problem.
I would switch back to your factory pulleys too. I don't think they free up enough HP to be worth the problems they can cause.
3.4" pulley! syrupsaleen Saleen & SMS Mustang 155 03-30-2012 09:25 PM
Crank pulley Sonicblue05 2005-2010 Mustang GT 2 12-29-2011 06:29 AM
Vortech S/c pulley size? 99redbeast SVT Mustang 5 11-19-2011 12:48 AM
Idler pulley jwhayne0001 1979-1995 Mustang GT 10 08-25-2011 04:48 PM
Water pump pulley Carlos92 Pre-2005 V6 Mustang 6 07-04-2011 07:55 PM
10:29 PM
