fuel filter - Page 2 - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 02-10-2012, 04:11 PM   #36
Giles85 is unknown around these parts
Re: fuel filter
Fuse box is inside car. I've thought that about computer too but looked it over and was unable to find a problem. Im sure its gonna be one of those things that I can't believe I didn't check. Well wish me luck.
Giles85 is offline
Old 02-10-2012, 05:33 PM   #37
Senior Member
Trojan Horse is just getting started.
Re: fuel filter
Well, Good Luck then.
Trojan Horse is offline
Old 02-11-2012, 07:56 PM   #38
Re: fuel filter
Ok so still no spark. I hooked a noise light up to the injector and am not getting signal to injector. Does this mean my computer is bad?
Giles85 is offline
Old 02-11-2012, 09:16 PM   #39
Senior Member
Re: fuel filter
That or you don't have power to the computer.
Old 02-13-2012, 09:59 PM   #40
Re: fuel filter
Ok so no injector pulse but getting pressure and no spark. I've ordered a computer for it. This has to be my problem right? Im mean im totally out of ideas here. Also what is a cas? Saw that in other threads
Giles85 is offline
Old 02-13-2012, 10:04 PM   #41
Senior Member
Re: fuel filter
Did you make sure you had power to your computer?
If you did and you have then it is likely the computer.
Never heard of a CAS that I can remember, are you sure it isn't CAI?
In what context was CAS used?
Old 02-13-2012, 10:08 PM   #42
Re: fuel filter
They were talking about miatas. But I didn't know either so I was confused. Also said something about it spinning I thought. Plus it wired into the ecm
Giles85 is offline
Old 02-13-2012, 10:10 PM   #43
Senior Member
Re: fuel filter
I don't have a clue as to what they were talking about.
Old 02-15-2012, 05:46 PM   #44
Re: fuel filter
Ok so I put in new computer and checked to see if I have power and if I have good ground. Still no spark. Please help. I am at a loss for any other ideas. Any thoughts
Giles85 is offline
Old 02-15-2012, 06:04 PM   #45
Senior Member
dreamstang is unknown around these parts
u said u had power going to the coil but no spark?did u change the coil?
dreamstang is offline
Old 02-15-2012, 07:09 PM   #46
Re: fuel filter
Yes I have changed the coil pip coil wire rotor computer and had the icm checked twice. No spark and no fuel ingectir signal. I pulled a plug and no fuel on it. Also checked for power at computer and checked the ground. No clue what's up. Been checking wires and no problem there. Any ideas? Also what is the thing that the injector wires run to before going to injectors? And there's is something that is right behind the intake that has a vacuum line going to it that goes to the intake. It also has three wires going into it?
---------- Post added at 08:08 PM ---------- Previous post was at 08:07 PM ----------
Im going to try a new thread and hope a new mind may have a thought.
---------- Post added at 08:09 PM ---------- Previous post was at 08:08 PM ----------
But please keep thinking on it. You have truly been alot of help. Thank u for taking the time.
Giles85 is offline
Closed Thread
fuel filter hose broke!!!!!!! 88fox 1979-1995 Mustang GT 20 11-25-2011 12:11 AM
should i have to change fuel.pump and fuel filter?? jmpark527 2005-2009 Mustang GT 11 11-11-2011 09:38 AM
Bad Fuel Filter? chrissiesstang Pre-2005 V6 Mustang 4 11-09-2011 04:51 AM
Fuel Filter replacement problem 99 SVT Cobra SVT Mustang 13 07-31-2011 07:25 AM
Fuel filter 04TRV6 1979-1995 Mustang GT 13 07-08-2011 03:21 PM
04:56 PM
