AOD to T5 Swap & Idle, Bucking Issues - Mustang Evolution
Old 02-06-2012, 12:32 AM   #1
I was recently surfing the net and ran across some information I thought might be useful for anyone doing an AOD to T5 transmission swap.It seems that the swap can lead to idle and bucking problems when taking off.
The AOD computer has a slightly different timing curve, that enables the computer to keep engine RPM's steady between shifts to avoid harshly engaging the gears. This difference can lead to problems when using the AOD ECU with a T5 transmission.
The theory is that the stock mass-air voltage transfer functions in the ECU must be modified to the match the load of the new engine combination. The EEC computer contains tables which correlate voltage from the mass air sensor to air-flow in kg/hr. A custom chip or aftermarket tuner should be able to resolve the issue.
Old 02-06-2012, 12:52 AM   #2
irishn8's Avatar
Interesting, thanx!
Old 02-06-2012, 01:33 AM   #3
Re: AOD to T5 Swap & Idle, Bucking Issues
Originally Posted by irishn8 View Post
Interesting, thanx!
You're Welcome.
I have ran across numerous discussions here and other places on the net about using the AOD computers in 5-speed cars and I figured their may be lots of people who might benefit from the information.
Old 02-06-2012, 03:48 AM   #4
Jamesgt08's Avatar
Yea I did the swap but I went from AOD to t45 swap. It drove horrible but as soon as I loaded my new tunes problem solved.
Jamesgt08 is offline   Reply With Quote
Old 02-06-2012, 04:15 AM   #5
Thanks for the confirmation.
Old 02-06-2012, 09:47 AM   #6
NeedSomeMods's Avatar
I swapped computers in mine, so, no problem with that! lol
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
« Mod Plan | New Hood »
95 gt rough idle and bucking issue Napoleon 1979-1995 Mustang GT 15 01-16-2012 04:09 PM
Idle issues HELP DHall31 General Mustang Discussion 9 11-23-2011 05:33 PM
06:40 AM
