Radiator support - Mustang Evolution
Old 02-06-2012, 04:43 PM   #1
Contourdrew's Avatar
Radiator support
How hard is it to replace a radiator support on a 94 gt
Contourdrew is offline   Reply With Quote
Old 02-06-2012, 06:03 PM   #2
Re: Radiator support
Depends upon how much experience you have with doing projects like that.
If you have no prior experience you will likely find it to be somewhat difficult.
You will have to remove the front bumper and everything attached to the radiator support.
Then cut loose the old support, clean up the weld areas, then position, check and weld in the new support.
Keep the car as level as possible and take accurate measurements before removing the old support. This will help you to ensure the replacement is properly located before you fasten it in.
05:44 AM
