Air bag light - Mustang Evolution
Old 02-06-2012, 11:01 PM   #1
captain78's Avatar
Air bag light
Ok changed my dashlight dimmer switch and all lights are working but now my stupid air bag light is blinking wth.
captain78 is offline   Reply With Quote
Old 02-06-2012, 11:05 PM   #2
irishn8's Avatar
That sucks man, all I can say is check ur wiring and fuses.
Old 02-06-2012, 11:07 PM   #3
Sky94GT's Avatar
I just recently changed my gauge cluster and am having the same problem. Feel your pain.
Sky94GT is offline   Reply With Quote
Old 02-06-2012, 11:14 PM   #4
Re: Air bag light
Have you tried removing the battery cables, draining the system and then reconnecting the cables to reset the system?
Old 02-06-2012, 11:19 PM   #5
captain78's Avatar
No not yet but I will give it a shot and see
Old 02-06-2012, 11:21 PM   #6
Re: Air bag light
The only thing I can think of is, if you changed the dimmer switch without disconnecting the power, you may have gotten a momentary short or voltage surge which affected the Air Bag light in some way.
Old 02-07-2012, 11:14 AM   #7
88gtCc's Avatar
Im with Trojan, Id try to discharge the whole system and see if the light comes back on. Disconnect the negative terminal, get in your car and depress the brake pedal for 10-15 seconds. Reconnect the negative terminal and start her up. Also because you'll be discharging everything, the ecu should clear itself of all its "learned perameters" as well. If you have a decent amount of mods (no chip/tune) it may run a little rough until the ecu re-learns how to cope with your mods.
88gtCc is offline   Reply With Quote
Old 02-07-2012, 12:11 PM   #8
captain78's Avatar
Yea as of now it's stock with a chip
---------- Post added at 12:11 PM ---------- Previous post was at 12:09 PM ----------
So just disconnect battery and press and hold brake for 10-15 seconds thought I would've had to disconnect battery for like 15-20 min
Old 02-07-2012, 01:28 PM   #9
I've always heard taking the leads off and holding them together.
Old 02-07-2012, 01:42 PM   #10
irishn8's Avatar
That would work, but that's just asking for trouble IMO. If you drain sensative electronics too fast, it puts a lot of stress on the circuits.
Old 02-07-2012, 01:58 PM   #11
Re: Air bag light
Disconnect both cables, positive first, then negative.
Pull on your headlight switch, leave on for 2-5 minutes, then turn off.
Reconnect cables, negative first, positive last.
Old 02-07-2012, 02:05 PM   #12
captain78's Avatar
Thanks
Old 02-19-2012, 07:23 AM   #13
90fox's Avatar
Mine blinks, but bought used came with aftermarket little gt wheel. So doesn't have air bag. How do I make light just disapear
90fox is offline   Reply With Quote
Old 02-19-2012, 08:04 AM   #14
captain78's Avatar
Good question that be good to know
Old 02-19-2012, 08:51 AM   #15
Re: Air bag light
Take the bulb out of the panel.
Old 02-20-2012, 09:57 AM   #16
captain78's Avatar
Well I followed what you said to do TH and I guess it didn't work lol.
Old 02-20-2012, 11:12 AM   #17
irishn8's Avatar
Sounds to me like you may have missed a wire or something when you did the dimmer switch work. Double check, make sure all wires are connected and in the right place. If that all checks out, have someone clear the computer or if u have a code reader or tuner, clear it urself then check wiring.
Old 02-20-2012, 11:14 AM   #18
Re: Air bag light
Try this - Mustang 1990-1991 Air Bag Diagnostic Codes and Debug Information
Old 02-20-2012, 01:17 PM   #19
captain78's Avatar
That's prolly what it is cause that's the code it's flashing 6
Old 02-20-2012, 05:56 PM   #20
Re: Air bag light
Make sure you read about how to work on it further down the page in the link I gave you.You don't want that thing going off in your face unless you really need it to do so.
Old 02-20-2012, 08:54 PM   #21
captain78's Avatar
I did lol urea that would not be good lol
Air bag light Bama blazer Pre-2005 V6 Mustang 2 12-07-2011 09:03 AM
air bag light 4u2nv General Mustang Discussion 5 10-25-2011 02:32 PM
Air filter RedGT04 1996-2004 Mustang GT 2 10-09-2011 08:29 PM
Intake Suggestions..... Srohda 2011-2014 Mustang GT 42 09-19-2011 04:56 PM
Vacuum lines coming from passenger fender well.? Otlaw80 1979-1995 Mustang GT 3 08-15-2011 08:01 AM
01:13 AM
