header question. - Mustang Evolution
Old 02-07-2012, 07:10 PM   #1
robert3188's Avatar
header question.
My current o/r x-pipe bolts up to my factory headers. Gonna replace them. Lookin for recommendations. And can someone explain the difference between equal and unequal length? Thanks in advance.
robert3188 is offline   Reply With Quote
Old 02-07-2012, 07:15 PM   #2
equal length all the runners are the same length.they end up looking like a pretzel and are more of a pita to install.but they will net u a couple hp do to the balanced flow on all cylinders.unequal all the runners pretty much go straight to the collector.these are the more common of the 2.
Old 02-07-2012, 07:16 PM   #3
Aggiesrok's Avatar
Unequal length go from the nearest port on the heads and combine into one tube so rear tube is much shorter than front tube. . Equal length- each exhaust tube on the header is the same length whether it's the tube near the front or back of the engine which makes the header longer but equalizes any back pressure.
Old 02-07-2012, 07:16 PM   #4
Re: header question.
If you are wanting a set of headers that allows you to use your current mid-pipe you will need to buy a set of shorties.
Equal length headers have every tube from the engine to the collector (where it connects to the mid-pipe) the same exact length. unequal length headers just run the pipe from the engine to the connector in the shortest route. The point of this is equal length headers allow the same flow and restriction for each cylinder equally.
Old 02-08-2012, 07:50 AM   #5
WhiteCobra94's Avatar
I'd personally go with equal length headers , BBK makes chrome equal lengths for $229 but you can go higher with JBA and Bassani which are around $500-$600 new!
Old 02-08-2012, 10:06 AM   #6
robert3188's Avatar
Will the equal length fit easy on my 5.0?
Another header question. AgentOrange 1996-2004 Mustang GT 17 02-07-2012 05:44 PM
Header question back n a stang 2011-2014 Mustang GT 7 12-20-2011 06:50 AM
Another Header question OrganDonor 2011-2014 Mustang GT 12 10-30-2011 01:54 PM
Header question Brandon91 1979-1995 Mustang GT 45 08-29-2011 02:33 PM
header question workmail21 1979-1995 Mustang GT 4 07-19-2011 02:20 PM
08:08 PM
