Rockers?! - Mustang Evolution
Old 02-08-2012, 10:37 AM   #1
88gtCc's Avatar
Rockers?!
What are they? Also how can I tell which ones I have? I have gt-40 heads but havent gotten the chance to open them up yet (came with the car).
88gtCc is offline   Reply With Quote
Old 02-08-2012, 10:49 AM   #2
Re: Rockers?!
If they are a good name brand they will have the name or logo and ratio stamped on them somewhere.
Old 02-08-2012, 11:03 AM   #3
88gtCc's Avatar
Alright, if they dont say anything on them I can assume I have "stock" 1.6's? Im also not entirely sure what their function is; this is the first car Ive had that has had them...I think. Lets say for example: I have gt40 heads, TrickFlow Stg1 cam, gt40 upper and lower intake (cobra one if that matters), 24lbs injectors and maf calibrated for it. Would I see any decent gain getting new rockers or should I not worry about them? Was thinking about going with a turbo soon (on3 with anderson pmu and fuel upgrades) just want to make sure I have everything in order first
Old 02-08-2012, 11:18 AM   #4
Re: Rockers?!
If you have stock rockers they will be stamped steel with no roller tips or fulcrum bearings.
Roller Rocker Arms do not make any horsepower.
They free up a bit of power by removing the friction at the fulcrum and tip.
A rocker arm's function is to open and close the cylinder head valves in sync with how the cam is ground.
Old 02-08-2012, 11:21 AM   #5
88gtCc's Avatar
Thank you Trojan!
Old 02-08-2012, 11:50 AM   #6
Re: Rockers?!
Thank you Trojan!
No problem, Good Luck with your project.
Old 02-08-2012, 01:16 PM   #7
Re: Rockers?!
Speaking of rockers, I just ran across these "stainless" roller rockers on eBay.Normally I would advise against buying things like this on eBay, but I have purchased parts from this guy before and he was honest and legit.
This appears to be a heck of a good deal on these arms.
Note that they are "stud mount" so you would have to make sure you had the correct style heads or be willing to buy the adapter kit for pedestal rocker arm heads though.
He has lots of other performance and dress up parts too.
White Performance
If you look up the cost of SS rocker arms from Comp Cams or other suppliers you can see how much of a bargain these might be.
Old 02-08-2012, 04:04 PM   #8
mystang50's Avatar
White Performance
Shoot yeah that is one Hell of a deal...wish I had a paypal and a eBay account!!
Old 02-08-2012, 04:15 PM   #9
WhiteCobra94's Avatar
White Performance
Crane Cam makes a kit for $110
Old 02-08-2012, 05:36 PM   #10
88gtCc's Avatar
So if I were to get some rockers it would free up some HP? Whats the average gain for my approx mods; 10hp-ish? Trying to weigh out my options atm. Thinking gears next (stock gears are looooong), but Im always up for suggestions!
Old 02-08-2012, 06:18 PM   #11
Re: Rockers?!
A stud conversion kit?
Those used to be around $50.
Old 02-08-2012, 06:21 PM   #12
Re: Rockers?!
I have seen claims that RR arms can free up to 20 HP, but I'd bet 10 maybe 15 at the most.
If you do all the mods you were talking about and it's properly tuned you should see in the neighborhood of 25 to maybe 50 HP increase I would think.
Old 02-08-2012, 06:34 PM   #13
5.slow's Avatar
Region: Delaware
So for gt40p heads I need pedestal mount rockers?
5.slow is offline   Reply With Quote
Old 02-08-2012, 06:39 PM   #14
I bought mine through summit and it was $109 for the studs, guide plates and guide plate inserts
Old 02-08-2012, 06:47 PM   #15
Re: Rockers?!
I think so.
Just look at them and see if they are stud or pedestal.
The pedestal rocker arms are bolted on.
Old 02-08-2012, 06:52 PM   #16
Re: Rockers?!
Wow, those used to be only $50.
I'm having a hard time believing they doubled in price.
But, I checked and they have just like you say.
Old 02-14-2012, 01:39 PM   #17
5.slow's Avatar
Region: Delaware
Gonna get the 1.7 roller rockers, do I need larger valve covers for those? If so, will I also need a spacer between my upper and lower intake ?
Old 02-14-2012, 01:52 PM   #18
Yes you will need larger valve covers and you might need a spacer but check and see how much clearance you have now!
Color match paint the '10-'12 GT oem rockers and valances M3hunter 2011-2014 Mustang GT 17 12-09-2011 07:27 PM
08:04 AM
