5.0 motor question - Mustang Evolution
Old 11-25-2007, 01:40 PM   #1
5.0 motor question
I have a 5.0 motor for sale the is in a 87' Thunderbird, is it true that Mustangs have the same motor ?
mattyohann is offline   Reply With Quote
Old 11-26-2007, 08:19 PM   #2
silverstangboy's Avatar
Re: 5.0 motor question
they do not.
camshaft is not the same
heads are but chamber volume is probably different
induction I believe is the same
serpentine belt system is completely different besides still using a reverse rotation water pump.
oil sump system is different..
Ideally this engine is very similar to the mustang fox 5 liter but not exactly, I have seen people put the thunderbird engine in a fox, most people usually keep the front end accessories of the mustang engine though.
93 mustang notch
~450hp 331 stroker - Sold
Old 11-27-2007, 12:12 AM   #3
If anyone wants it Email myohann@centurytel.net
Old 01-17-2008, 07:38 PM   #4
Mercedez L.'s Avatar
No at one time the Lincoln Continental had a 5.0 the 2 door model. I think it was a LSC model?
Mercedez L. is offline   Reply With Quote
Old 01-26-2008, 10:41 PM   #5
Vinnietbird's Avatar
O.K.,here's the deal.The H.O Mustang had E7 heads.The Bird has E6's.The upper intake is different.Visually they look the same,but the Mustang's is better.The Stang has a 60mm throttlebody,the Bird has a 50.The Stang has valve reliefes and forged pistons,the Bird has flat tops,not forged.The H.O Stang engine has the High Output cam with the 351 firing order,and the bird has the low power (150 horsepower) standard 5.0 cam with the standard 302 firing order.The Stang also got factory headers,the Bird didn't.As for the Lincoln,there was a Licoln mark VII with the 5.0 H.O engine.In '86 and '87,it had he forged flat top pistons,and was the same engine as the '86 GT Mustang.Although the Stang went to Mass Air,the Lincoln Mark VII did not,although it did continue to use the Stang engine.In '88,the Mark VII got valve relief pistons.Now you know the rest of the story.
Vinnietbird is offline   Reply With Quote
Old 01-26-2008, 10:52 PM   #6
Thumbs up Re: 5.0 motor question
The California GT 5.0 in 1988 came with Mass Air before all the other states.
Old 01-26-2008, 10:53 PM   #7
So did that Lincoln Mark VII have a comfortable soft ride unlike the Stang?
Old 01-27-2008, 06:49 AM   #8
True about the California sold Stangs having Mass Air.The Mark VII,and Mark VII in LSC form had an air ride suspension.The cars were great for comfort,but many of the cars suffer from worn components which cause the suspension to not raise or lower,or both as it should,and parts can be very expensive.Many Mark VII owners swapped in Cougar or Thunderbird front K-members and standard suspension,and standard springs in the back instead of the air ride pieces.
1988 Thunderbird Sport...GT-40P engine, ported heads,Crane Gold 1.7 roller rockers, TFS-1 cam,Cobra intake,24# injectors,Mass Air, 8.8 with 3.55's, BBK headers, Pypes X-Pipe,40 series Flowmasters,3 row radiator,Taurus fan,17x9 and 17x10 10th ann. Cobra wheels,and more.....
Old 01-27-2008, 02:59 PM   #9
The idea of having a great handling car with a nice soft ride that protects you from these bad roads and doesn't beat you up with straight line performance is very appealing.
Old 01-27-2008, 05:04 PM   #10
rocknbronco's Avatar
No just a bigger backseat.
rocknbronco is offline   Reply With Quote
Old 01-27-2008, 11:58 PM   #11
2:
Old 01-28-2008, 07:48 AM   #12
:drive:
Old 01-28-2008, 10:48 PM   #13
2:
Old 01-29-2008, 09:43 PM   #14
cool info vinnie,
i've never been a junkyard builder myself, though congrats to anyone that is/does, I didn't know there was so much different about the bird motor and the mustang... most of the stuff on that list though can be fixed with any decent build, even the later mustang engines ran cast pistons, albeit they still have valve reliefs in them, im not a fan of putting forged in a low HP build anyways, with a standard compression height cast puts up to alot more abuse than people let on.
got any pictures of your bird vinnie?
93 mustang notch
Old 01-30-2008, 04:37 AM   #15
I'll see what I can find as far as pics go.Stay tuned.
Old 01-30-2008, 04:40 AM   #16
Here's the engine,and a burnout shot on main Street.Those were polished Turbo Coupe wheels which were sold and the car wears 17x9 Cobra R wheels now.It in a few colors now as well,we're getting ready to repaint,added a Turbo Coupe hood and a few other things.This is the only shot I have until I break out the camara again.
Old 01-30-2008, 04:41 AM   #17
A couple more....
Old 01-30-2008, 11:33 PM   #18
A couple more....
Looks good
Old 02-01-2008, 04:31 AM   #19
Thanks a lot.Wait 'til I finish.It'll be a totally different car.
Old 02-01-2008, 11:23 PM   #20
keep us all in touch with your results.
Old 02-03-2008, 04:43 AM   #21
Will do.I just picked up another Turbo Coupe rear at the boneyard and will install it soon instead of rebuilding the one in the car now.I hope to have the 5 speed in before the end of March.We'l see what happens.
Old 02-03-2008, 05:51 AM   #22
Question Re: 5.0 motor question
Being more of a luxury car wouldn't an automatic be better in that t ype of vehicle?
Old 02-04-2008, 06:47 AM   #23
Not really.My car weighs in at 3300 pounds.Not bad whn you compare it to a same year Stang GT.The biggest difference is that the wheelbase is about 6 inches longer.The suspension,drivetrain,exhaust,all of it is Stang parts.I had to extend the tailpipes a few inches,and the mid pipes a few.No big deal.I've already spanked many Mustangs with this car,and a 5 speed will let me take better advantage of the engine I have.
Old 02-04-2008, 04:12 PM   #24
Hey there Mercedez I Like the new Pic
Truth is Truth whether YOU believe it or not:)
www.bigdmustangs.com
mustero is offline   Reply With Quote
Old 02-04-2008, 10:50 PM   #25
Wink Re: 5.0 motor question
Thank you
Old 02-04-2008, 10:52 PM   #26
Why don't you get that car coming out the CTS-V CAD it comes with both auto trans or manual. 550 HP
Old 02-05-2008, 06:12 AM   #27
I think my next car will be a 2004 Mustang GT.I wouldn't trade my Bird for anything.It's not necessarily worth much since it is a non-collectible car,but,it has a lot of personal value since I built it (and still at it) with my own hands from the ground up.I have a ways to go with it still.If I could have anything I wanted,it would be a 1970 Plymouth Hemi Superbird.Awesome,just awesome.
Old 02-05-2008, 09:03 PM   #28
Talking Re: 5.0 motor question
You are probably right as is the same in my situation an 88 5.0 GT in excellent condition wouldn't bring in enough $$$ to make a difference to get another vehicle and so since it has been in my family for 20 years we keep it. Sentimental value?
2004 GT I would go for the 2003 0r 2004 Mach 1
Old 02-06-2008, 07:04 AM   #29
I like the Mach 1 a lot,but for the money,I can get a GT and a few peformance upgrades and still be cheaper then the Mach.The Stang would become my daily driver while my time and effort would apply to the Bird.
Old 02-06-2008, 04:45 PM   #30
That is a great idea.
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
What motor..... bullitt482 General Car Discussion 9 02-16-2007 04:44 PM
New Best On the Motor v6stanger Pre-2005 V6 Mustang 4 02-25-2006 08:04 PM
New Motor GT-Eater Pre-2005 V6 Mustang 30 07-18-2005 12:01 AM
Motor swap question. ShwoffGT 1996-2004 Mustang GT 32 02-21-2005 09:57 AM
04:57 PM
