Popping out pipes - Mustang Evolution
Old 02-10-2012, 06:33 AM   #1
Quball19's Avatar
Popping out pipes
Just rebuilt motor getting a popping sound out pipes, kinda like a back fire. Its fuel injection...... Any help I would love
Quball19 is offline   Reply With Quote
Old 02-10-2012, 08:27 AM   #2
rameyg972's Avatar
Is the timing set correctly, the distributor may be a hair retarded. Advance it a fraction and see if that helps, anyone else have an idea?
rameyg972 is offline   Reply With Quote
Old 02-10-2012, 09:10 AM   #3
Quball19's Avatar
How do you turn down richness? Mine goes away more at high rpm
Old 02-10-2012, 09:42 AM   #4
rameyg972's Avatar
I just put a 289 in my 88, it started out doing the same thing. In the 289 I had to rotate the distributor clockwise (advance) to stop the popping.
Old 02-10-2012, 09:42 AM   #5
Mine did that also only at high rpms or If I was getting on it real hard. Sounded like it was missing but it was popping out the exhaust. It turned out to me a spark plug that the white part was cracked. I changed the one spark plug and it went away. So Check all the obvious things first. !!!
Robbie94gt is offline   Reply With Quote
Old 02-10-2012, 09:42 AM   #6
Newline's Avatar
Check your maf for any debris and verify a good reading there and the iat and ect
Newline is offline   Reply With Quote
Old 02-10-2012, 09:56 AM   #7
rameyg972's Avatar
I'm not up on all the fuel injection, but it may be the inputs from the computer (if so equipped)...it sounds like it may be telling the injectors to inject more fuel than what is needed...
Old 02-10-2012, 10:23 AM   #8
Newline's Avatar
^^^ see above sensors
Old 02-10-2012, 11:29 AM   #9
Quball19's Avatar
Should I put a fuel regulator on it to control fuel? I have stock one on it. I have 24# injectors on fresh rebuild
---------- Post added at 12:29 PM ---------- Previous post was at 12:16 PM ----------
mine does it more on lower rpms, yes sounds like missing out.when I stomp it it goes away. I will check plugs thanks
Old 02-10-2012, 02:45 PM   #10
Re: Popping out pipes
Tune it!
If you don't have one get a Chilton's or Haynes manual for your car.
Check timing, fuel pressure and assure that all of your sensors are good and working correctly.
SLP race pipes... leviz79 1996-2004 Mustang GT 0 01-04-2012 12:47 AM
Flamethrower from tail pipes shsfresh87 General Mustang Discussion 8 12-14-2011 05:01 AM
Will 96 cobra pipes. Fit my 2003 v6 Bama blazer Pre-2005 V6 Mustang 3 12-04-2011 08:35 PM
Popping sound while braking... 12GTstangCS 2011-2014 Mustang GT 4 11-29-2011 12:55 PM
12:43 AM
