Changed dist runs crappy now - Mustang Evolution
Old 02-10-2012, 12:48 PM   #1
Cm644rodrigues's Avatar
WEll old distributor crapped out so changed it out with new. Like a dummy I didnt mark the old dist so I found tdc by hand cranking and installed dist with 1at tdc. Car started and I played with timing by ear. Sounded as good as always. Took it for a drive and and it feels like I'm driving with the ebrake on. Doesn't wanna go. I did notice at full throttle I get a backfire. How could my timing be off if I found tdc and it started right up? Any fixes for my problem. Thanks
Cm644rodrigues is offline   Reply With Quote
Old 02-10-2012, 01:58 PM   #2
Re: Changed dist runs crappy now
Your timing is likely off a tooth or two.
When the #1 piston is at TDC, the rotor inside the distributor needs to be pointed directly at #1 plug wire terminal on the distributor cap.
Make sure you are at TDC on the compression stroke.
Otherwise you could be 180 degrees off.
Once you are sure you have it installed correctly, then time the engine with a timing light.
Don't forget to remove the spout connector when you are setting the timing.
If you don't, it will not work properly.
Old 02-10-2012, 03:31 PM   #3
stampde's Avatar
+1 + 1+ 1+ 1
2011 GT Auto
Old 02-10-2012, 05:32 PM   #4
Originally Posted by stampde View Post
+1 + 1+ 1+ 1
Thanks for the confirmation.
Old 02-10-2012, 05:55 PM   #5
I've tried it a few times so may just be tired. I'm probably just gonna take off the valve cover tomorrow. So I turned over the engine and felt compression at the 1 plug hole and put rotor at 1 when compression was highest. Shouldn't this be right
Old 02-10-2012, 06:13 PM   #6
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Have u tried taking the number one plug out, put a screwdriver in(helps if u have a friend) and turn it over by hand until u feel the piston push the screwdriver as far as it will go up before dropping back down then set the dist?
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 02-10-2012, 06:50 PM   #7
Yup used an old clean pushrod and it seemed like the piston was at the top of its travel and set the distributor and still feels sluggish and getting backfiring.
Old 02-10-2012, 07:30 PM   #8
From what it sounds u did it right.but u def made sure the dizzy was pointing at the # 1 under the cap like TH stated while the # piston was at tdc?
Old 02-10-2012, 07:38 PM   #9
Like I said, you have to make sure you are coming up on the compression stroke.
Otherwise, your timing will be off.
02:18 PM
