Nitrous with carb - Mustang Evolution
Old 02-10-2012, 02:18 PM   #1
351mustang's Avatar
Nitrous with carb
Will I have to raise the fuel pressure if I decide to do a 100 shot of nos?
351mustang is offline   Reply With Quote
Old 02-10-2012, 02:35 PM   #2
Re: Nitrous with carb
Maybe, if you are using a "wet" kit.
You will have to see what it does to your fuel pressure when you activate the nitrous.
The best bet is to go to the manufacturer's website and follow their directions for installation and fuel supply.
Old 02-10-2012, 02:44 PM   #3
351mustang's Avatar
Yes it's a wet kit. What pressure should I be at with a carb 9psi?
Old 02-10-2012, 02:47 PM   #4
Probably between 5-8 psi.
If I remember correctly, going any higher will require special needles and seats to hold the pressure.
If your pressure does not fall way off when you activate the nitrous/fuel solenoids, then you are probably ok with it set where it is at.
Old 02-10-2012, 03:17 PM   #5
351mustang's Avatar
Oh yeah I know all about blowing out the seats and needles due to a faulty fuel reg. thanks for the info
Old 02-10-2012, 05:25 PM   #6
I bet an easier fix for supplying enough fuel to the nitrous system fuel solenoid might be to just use a separate pump & regulator?
I don't think you would need an expensive pump, one of the over the counter electric fuel pumps would probably work.
Old 02-11-2012, 04:47 PM   #7
351mustang's Avatar
I have a second one I'll look into it
nitrous
intake and carb dreamstang Mustang Parts for Sale and Wanted 9 04-05-2012 04:55 PM
Nitrous Help? soccerfreak2143 General Mustang Discussion 12 02-09-2012 07:37 PM
Nitrous kits Stockish302 1979-1995 Mustang GT 5 10-27-2011 05:48 PM
Nitrous and a tuner explicitrock Pre-2005 V6 Mustang 2 07-29-2011 09:01 AM
Carb stroked_88 1979-1995 Mustang GT 1 07-24-2011 10:27 PM
01:16 PM
