Popping out pipes 2 - Mustang Evolution
Old 02-10-2012, 08:41 AM   #1
Mustang_Madness's Avatar
Popping out pipes 2
Originally Posted by rameyg972
Is the timing set correctly, the distributor may be a hair retarded. Advance it a fraction and see if that helps, anyone else have an idea?
This happens to me as well. At least when i accelerate in upper RPM range... My scanner says its running too rich so i would assume that Thats the problem...
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 02-10-2012, 09:08 PM   #2
I have cleaned the MAF, the IAC and my throttlebody. I also seafoamed the **** outta the intake and throttlebody. As well as cleaned the CAI and replaced the oil pressure sending unit, and filter because those were leaking... I dont know what else to do
Old 02-10-2012, 09:34 PM   #3
Re: Popping out pipes 2
Tune it!
If you don't have one get a Chilton's or Haynes manual for your car.
Check your timing and fuel pressure.
Old 02-10-2012, 09:43 PM   #4
Originally Posted by Trojan Horse
Tune it!
I dont have the software! I HAD the software! But lost it i have the tuner just no disk and forgot which tune it is...
---------- Post added at 11:43 PM ---------- Previous post was at 11:43 PM ----------
Tune it!
I have BOTH the haynes and chilton manual
Old 02-10-2012, 10:12 PM   #5
There is no need to get excited and emphasize that you had software or that you have both manuals.
We were not talking about software and software won't tune your engine for you.
I was not talking about a tuner, I was saying tune the engine.
Nothing you did, will do anything toward fixing the problem you described.
Use your manuals and look up how to tune up the engine.
Set the timing and check your fuel pressure.
Check your spark plugs, wires, distributor cap and rotor.
What kind of "tuner" do you have anyways?
Old 02-10-2012, 11:23 PM   #6
Ohh I gotcha man! Its the Special Forces Sniper Tuner.. I got it with the car... but I definitely will. Thanks!
Old 02-11-2012, 01:26 PM   #7
Bad news.
I researched that tuner at Delta Force Tuning
I could not find it on their website, it may be out of date and no longer manufactured.
They do have an update to the "Commando" Software for $341, but you have to have proof of purchase for the Special Forces software to even get that.
The only things they have that appear to be compatible with the 88-95 Mustangs are the "Commando Software" at $645, and the "Delta Force Software" and that runs $1800. Then to be able to use them you have to buy a "Plug In Chip" at another $227 along with a "8-Position Cable Switch" at $114 and a "Ford Chip Burner" at $270.
$1270 to $2411 total depending on which software you choose.
Makes my AFM PMS look cheap at $970.
I was interested to see that there may be other tuning options for the 88-95 Mustangs until I saw their prices and noticed that they have no listing or description of exactly what their tuner will do or even an instruction/installation manual to look through.
Old 02-11-2012, 06:46 PM   #8
Bad news.
Seriously?! Damn... I know its the sniper tuner and i have the cords and Everything. I have the tuner its self so i Really need to find that software!
Old 02-11-2012, 07:27 PM   #9
Yes, and ask whoever you bought it from if they can find the receipt.
Old 02-12-2012, 12:31 AM   #10
They got it from a guy before them! I will just find the disk
Popping out pipes Quball19 1979-1995 Mustang GT 9 02-10-2012 02:45 PM
SLP race pipes... leviz79 1996-2004 Mustang GT 0 01-04-2012 12:47 AM
Flamethrower from tail pipes shsfresh87 General Mustang Discussion 8 12-14-2011 05:01 AM
Popping sound while braking... 12GTstangCS 2011-2014 Mustang GT 4 11-29-2011 12:55 PM
06:43 AM
