1997 Explorer engine in 1989 convertible - Mustang Evolution
Old 02-11-2012, 02:26 AM   #1
kbolden50's Avatar
Im going to a shop and pick up a 97 explorer 5.0 engine with gt-40p heads and i looked up the swap and what i got out of it is change all front parts and timing cover balancer i want to know if thats all and can i use 5.0 mustang flywheel and the balancer off a 5.0 mustang and it work and can i use a 1989 Lincoln mark
---------- Post added at 08:26 AM ---------- Previous post was at 08:21 AM ----------
[QUOTE="kbolden50"]Im going to a shop and pick up a 97 explorer 5.0 engine with gt-40p heads and i looked up the swap and what i got out of it is change all front parts and timing cover balancer i want to know if thats all and can i use 5.0 mustang flywheel and the balancer off a 5.0 mustang and it work and can i use a 1989 Lincoln mark vii 5.0 HO cam in the 97 engine thank you
kbolden50 is offline   Reply With Quote
Old 02-11-2012, 08:09 AM   #2
93slowstang's Avatar
Yes you can use the cam, balancer, and timing cover, all the parts will swap over just fine. You also need to use your distributor being the explorer is EDIS.
Old 02-11-2012, 10:29 PM   #3
kbolden50's Avatar
Could i use the old roller rockers and rods or should i go new do i have to change oil pan
Old 02-12-2012, 01:16 AM   #4
I would change the lifters and check the rods to make sure they are straight. You should be able to reuse them as well as the rockers.
Old 02-12-2012, 09:17 PM   #5
kbolden50's Avatar
I looked at the rods on the 89 they are bent could i use the 89 rockers and the 97 rods i was going to check the size but with it bent would that make the off some
Old 02-13-2012, 07:14 AM   #6
Re: 1997 Explorer engine in 1989 convertible
The push rods are probably the same length or close enough that it won't matter.
Old 02-13-2012, 11:31 PM   #7
+1. I used the explorer pushrods and rockers on my swap awhile back. No problems to date with them.
Old 02-14-2012, 01:23 AM   #8
kbolden50's Avatar
Ok thank you both best help on this site hands down
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 02:31 PM
Engine swap question!! Tominkc 1996-2004 Mustang GT 1 02-09-2012 01:15 AM
Good engine to put in 89 convertible kbolden50 1979-1995 Mustang GT 12 01-27-2012 11:24 PM
selling a 1989 4 cylinder mustang with a 5.0 engine and transmission both working 1987mustanglx50 2.3 Mustang 0 01-25-2012 02:30 PM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 03:11 PM
04:44 AM
